Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 145 votes, 5.00 average. Display Modes
Old 01-19-2014, 12:42 AM   #1
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Smile Eonon GM5150
"Eonon D5150 Install Thread"
(Need help installing the GM5150 click the link above, both units are similar)
External Mic is now included on the GM5150 (Item #28).
The extended installation harness A0566 (17Pin), A0567 (40 Pin) which fits BMW E46 with OEM NAV.
Check more details here:
http://www.eonon.com/Others/Kits-and-Harness/A0566.html
http://www.eonon.com/Others/Kits-and-Harness/A0567.html
Just released, the New GM5150. $407.00
http://www.eonon.com/Car-GPS/Specifi...MW/GM5150.html
The powerful function "Screen mirroring" will be integrated into Eonon D5150. The Eonon GM5150 BMW E46 GPS has been released proundly with all the functions of D5150 + unique Screen Mirroring Function! Further more, it also has the the New OEM BWM UI updated.
GM5150=D5150 (NFC URC) + Screen Mirroring + NEW OEM BMW UI
-Main features of GM5150:
Specific For BMW E46 1998-2005
- New OEM BMW UI
- Screen Mirroring
- NFC URC
- ARM11 Processor
- Tire Pressure Monitoring ( TS01 )Compatible
- Digital TV (V0018)Compatible
- GPS, US/CA/EU/AU/NZ Map Optional
- GM5150 Group Buy Price:
Original Price: $407 on our website
GB Price:$379 without map
Save 25%!
- EONON GM5150 Group Buy -
http://forum.e46fanatics.com/showthr...ighlight=eonon
WARRANTY INFO:
If you purchase the 5150 from Eonon's eBay store it comes with a 1 year warranty.
If you purchase the 5150 from Eonon's website it comes with a 2 year warranty.
http://www.eonon.com/2YEAR_WARRANTY.aspx
Contact Carlos from Eonon for Technical Support.
http://forum.e46fanatics.com/showthread.php?t=1001181
Upgraded to the Eonon GM5150 from the D5150. First I must say I was pretty happy with the D5150 but I really liked the new UI Eonon did with the GM5150. After receiving the unit I noticed right away Eonon listened to our feedback and lengthened the RCA wires and included a 90 degree iPod cable. These two additions make the install way easier! The RCA wires on the original D5150 were 75mm and on the new GM5150 they are 140mm's. Also there is a small black pad underneath the unit, this is there for a reason do not remove. This actually helps keep the unit sitting more secure in the dash. Simple but effective solution.
The biggest differences I have noticed from the D5150 is the Orange LED's to match the BMW dash. The Bluetooth Mic works really good. I tested a call and it came in loud and clear, I even put my finger over the Mic hole on the unit and there was NO difference in the call quality! The new UI is the biggest thing I really like about the GM5150. Every screen was redesigned and looks so much better. Small tweaks like moving the dimming button to the far left instead of the center, easier to reach while driving. The remote control is a leap forward from the old one, way to go Eonon! The clock size was reduced and moved to the far left and can be turned off if desired.
Here are a few minor issues:
1- The clock won't keep correct time.
(Set to GPS sync and the correct time zone)
http://en.wikipedia.org/wiki/Mountain_Time_Zone
2- The unit goes to A2DP music streaming on most start ups.
(Turning Auto Connect Off Corrects this)
I experimented with three different radio antenna adapters to address the radio reception issue. The one that comes from Eonon works best without the Blue wire connected.
The adapter I had previously used with the D5150 was slightly better, the 40-EU10. The one I found that works the best and eliminated most of static and weak reception is 40-EU55 the. It's for 2002 and up BMW's with powered antennas and newer Facra style antennas and is approx $13.
Adapter is a Metra 40-EU55
http://www.amazon.com/METRA-40EU55-A...=metra+40+eu55
http://www.amazon.com/Metra-40-EU55-...=Metra+40-EU55
Installing the 5150 requires a relocation bracket. This part cost approx $85 from ECSTuning. There are two different ones available depending on which button console you have. This part is needed for lowering the AC controls down below making room for the 5150 on top. When you relocate the heater / AC controls what you want is BMW part number 51167001410, ECS part ES#82727.
Here's more information about the differences between the two "single cutout" mounting brackets...
51167001410: Single cutout version w/ smoker's package
51167001408: Single cutout version non-smoker's package
The non-smokers package allows for easy installation of the front storage compartment 51168208369 and does not include the LED light. You can retrofit the compartment tray into a smokers unit but there's a little tab that needs to be cut out.
Cigarette lighter block off plug 51168222183.
Functionally either one will work but if you get the wrong one you will have a gap in the lower corners.
Some installation videos on how to take apart the dash and remove the Stereo, AC controls and Storage bin. Here is a helpful tip for removing the center vent, use two plastic cards (old credit cards/store membership cards) and slide them into the top left and right corners of the center vent. This will release both clips.
GM5150 INFO VIDEOS
- Radio -
- Navigation -
- Bluetooth -
- DVD -
- Settings -
"How To Update the Firmware in the EONON 5150"
http://www.e46zone.com/forum/topic/4...mware-upgrade/
-Firmware updates-
There are three different ones to choose from:
This is the Firmware my GM5150 came with.
BMW_APP_TW_4049-405F-0709-L146-131209
This Firmware was to address the Launch.exe error.
BMW_APP_TW_4049-405F-0709-L146-140219
This is the latest Firmware update from Eonon, 10/14/14.
BMW_APP_TW_4049-405F-0709-L146-140704
I assume NO responsibilty, proceed at your own risk.
Instructions:
1. Copy the folder of files to the SD card.
2. Turn the key to position one and turn on the head unit.
3. Inserted SD card and leave the Eonon head unit on.
Turn off the key, wait 10 seconds, then turn the key back to position one and the head unit will power back on and read the SD card, Do Not Turn Off the Unit!!.
4. It goes through about four steps, then restarts, please calibrate the touch screen per the instructions.
5. Remove the SD card and hit reset. If you forget to take out the SD card, it reloads again.
More Detailed:
1. Copy the NWD_703 folder of the firmware update to your GPS SD card (make a backup of your current GPS software and maps) now the only thing on you SD card should be the NWD_703 folder.
2. Turn unit on without sd card till it fully boots (dont worry if you are getting a launch.exe error right after starting your unit, this doesnt seem to effect it)
3. Turn the unit off by turning your key to the off position for 10 seconds
4. Place your SD card into the GPS card slot and turn the key to the acc position. You should see a Eonon logo and the unit should start auto updating itself.
5. Once completed the unit will have you re-calibrate
6.After calibration go to settings and select the option just under GPS and select your language (settings wont look set until you hit the home button)
7. After confirming you have the correct language set, then turn your key to the off position again and take out the sd card (if you forget it will just do the process all over again)
8. Turn key back to the acc position and let the unit start fully.
9. Once the unit has started, find a sharp object and hit the restart button above the GPS card slot to further confirm NO issues.
10. Load all your GPS software back onto the sd card and remove the NWD_703 folder.
-SETTINGS-
Time display: Display/undisplay time on top left of the screen.
Hand Brake: Switch on/off Brake detect.
Key Tone: Switch on/off key tone.
Rearview Startup: Turn on/off rearview camera.
Headlight Control:Turn on/off headlight control mode. Headlight on, the screen auto dimmer.
Navigation Mixing: Turn on/off navigation mixing mode.
Turn ON Mix Mode: Sound of GPS Navigation will be played with playing sound synchronously.
Turn OFF Mix Mode: When navigation sound on, the music of front speaker will stop, the rear speaker will stay on. After navigation sound stops, front speaker will continue to play music.
Mix Ratio: Set mix ratio of navigation soundwith music or radio.
Radio Region: User could select radio frequency from (Europe, South America, Japan, Taiwan and America). Frequency of broadcast status will run under corresponding frequency automatically once selected.
Reversing Video: on/off. Please turn off "reversing video function" if your car hasn't installed a rear view camera.
-Screen Info-
The small "Sun Icon" top left. Press it and it changes to "Half Moon" and the screen dims, press it again and the screen is turned off. Touch the screen or steering wheel controls to turn it back on.
Build Thread - S54 Vanos Thread
TTFS Engine/SMG Tune - SGT Headers/Sect 1/SCZA - Evolve Eventuri - Sprint Booster V2
UltraGauge - Orion V4's - CF Lip/Console/Diffuser - VIS XTS CF Hood - CSL Trunk - Valentine One - Turner 15F/12R Spacers
WOLFN8TR is offline   Reply With Quote
Old 01-19-2014, 12:42 AM   #2
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Mounted the WiFi Antenna behind the glove box with 3M tape.
Here is what the screen looks like with direct sunlight on it. Brightness turned up all the way.
- Rear View Camera Options -
- $30 -
http://www.amazon.com/NEEWER-Waterpr...pd_sim_sbs_e_4
http://www.aliexpress.com/item/Free-..._3865011&vd=30
http://www.aliexpress.com/item/Wirel..._3865011&vd=30
- License Plate Light Camera, Best OEM Look -
- $20 -
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
- Surface Mount Camera mounts under the Trunk Cowl with Screws -
http://www.amazon.com/Century-Access.../dp/B00ED56OY4
http://www.ebay.com/itm/400555291931...%3AMEBIDX%3AIT
- License Plate Frame Camera -
http://www.amazon.com/TaoTronics®-TT.../dp/B0092YMZJY
http://www.ebay.com/itm/111089430476...%3AMEBIDX%3AIT
- License Plate Camera -
http://www.amazon.com/Crimestopper-S...+backup+camera
http://www.ebay.com/itm/400548200687...%3AMEBIDX%3AIT
If you are Replacing the OEM Navigation:
(Thanks to the following for their assistance replacing the OEM Nav.)
DetroitFarher
Maxfury929
Steve@elljes
If your connector is a 17 pin.
http://www.ebay.com.au/itm/BMW-Wired...d=494138412906
http://www.ebay.com/itm/331102232297...%3AMEBIDX%3AIT
If your connector is a 40 pin.
http://www.ebay.com/itm/BMW-Wired-Ca...81099081826%26
http://www.ebay.com/itm/321293141815...%3AMEBIDX%3AIT
17 PIN Wiring Extension Harness.
40 PIN Wiring Extension for OEM Nav.
Old 01-19-2014, 12:49 PM   #3
brewer90
My Ride: 06 330Ci ZHP
Looks like their spell checker fell asleep on the job. Genernal
brewer90 is offline   Reply With Quote
Old 01-19-2014, 02:37 PM   #4
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Whoa I didn't even catch that! Nice find...
Old 01-19-2014, 09:15 PM   #5
racinstylez
My Ride: 2000 323ci
On the Eonon website, its saying its Sold Out for the group buy? Maybe I am just getting an error?
racinstylez is offline   Reply With Quote
Old 01-19-2014, 10:30 PM   #6
EononCarDVD
EononCarDVD's Avatar
My Ride: BMW E46
Hi Gary, glad to hear that you have GM5150 installed already. thank you for your great support to Eonon. We appreciate your effect so much.
Yes, we have made improvement on GM5150. Thanks to the understanding of all your guys, and also give us chance to improve our product, that is why we can make more stable and powerful unit for better use! Thank you!
Regarding 2 issues you mentioned.
Have you turned on the GPS sync and also set it to the correct GPS time zone? Will it help you hold the time memory?
Yes, D5150 with URC and also GM5150 designed in this way. It is not the product defective. But i have reflected it to R&D and they will collect more information, then decide whether will change it in the future.
Thank you again,Gary
Top-notch Eonon Android Car Stereo. Change, why wait.
Welcome to check our cool new GA7150 BMW E46 Android 6.0 Car GPS with 12GB for Apps, more powerful and intelligent than ever!
15 Rounds of Group Buy have been arranged till now! PM me anytime if you'd like to join and save!
EononCarDVD is offline   Reply With Quote
Old 01-19-2014, 10:41 PM   #7
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
No problem, glad to help out.
The clock issue I actually tried that but I will experiment with the time zones. These are very small quirks I can live with. I'm really impressed with the new UI and small changes that were made. The longer RCA wires and the 90 degree iPod cable made it so much easier to install. Thanks for listening to the feedback from you're customers and making these changes. The Bluetooth Mic seems to work good now also. I noticed the volume control is more stable and consistent than my D5150 was.
Old 01-20-2014, 01:13 AM   #8
wacuna
My Ride: BMW 323i
My main issue is the steering wheel functions, the button to answer the phone calls change the "equalizer mode" and the button to go to Bluetooth change the "mode"... there is any way to set it up properly?
wacuna is offline   Reply With Quote
Old 01-20-2014, 03:06 PM   #9
VKnid
My Ride: 2002 330i
I learned a few things after installing the backup camera today.
1. I can confirm that the radio reception is much better after disconnecting the blue wire from the Eonon supplied antenna adapter.
2. This camera seems to be working well, but it was definitely not easy to fit. Requires some creative Dremel work and double sided tape to get it to fit into hole left after removing the license plate light.
Waterproof 170°Night Vision Color Car Rear View Back Up Camera for BMW E39 E46 -$18.
3. The wiring for the camera was pretty straight forward especially using the D5150 install tread as a guide as well as this thread for the wiring: http://forum.e46fanatics.com/showpos...02&postcount=4
4. It was not necessary to connect the orange trigger wire from the back of the GM5150 into the blue/yellow wire behind the glove box (at least not with that camera getting power from the back up light in the trunk lid). This was a good thing because I could not figure out how to disconnect the wire box from above the fuse box.
5. Carlos sent me a software update that is supposed to fix the automatic A2DP on start-up issue. Haven't tried it yet. I have to get a new SD card first. Anyone confirmed that it works?
6. The clock will sync itself if you have the right timezone set and turn GPS Sync ON. Sometimes it take a minute, but it's no longer annoying.
7. Also I took the opportunity to trim down the antenna adapter while the unit was out. Don't know if they changed it from the D5150 or not, but a little trimming goes a long way towards getting the unit to fit flush.
VKnid is offline   Reply With Quote
Old 01-20-2014, 05:52 PM   #10
shingo43
My Ride: 04 325ci
Could the firmware be used in D5150?
shingo43 is offline   Reply With Quote
Old 01-20-2014, 05:59 PM   #11
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Look in the settings menu, you can assign the steering wheel buttons. I haven't tried it yet but it has the option.
VKnid
Good to hear all went well!
I tried to use the GPS Sync and the correct time zone for my clock and it works most of the time. It does take a few minutes to sync up when you start the car. The time will change to the correct time. I've had mine still be off by 10-15 minutes a few times thou.
Did your backup camera have a Red wire running from the back to the front with the RCA wire? If so that's why you didn't need to hook up the trigger wire under the dash.
Old 01-20-2014, 06:15 PM   #12
VKnid
My Ride: 2002 330i
I was told that it would only work with the GM5150 with the new interface.
VKnid
The manual says that the buttons can be programmed, but I haven't been able to get it to work. Don't know if anyone has for that matter. There are two orange wires labeled sw1 and sw2 (not the RCA wires for sub woofers) that may have something to do with programming, but I have no idea what they would connect to.
There was a red wire coming out of the camera with the yellow RCA, but it was only long enough to run to the reverse light not all the way to the front.
Old 01-20-2014, 07:32 PM   #13
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
So you didn't have to even wire up the Orange "Back" wire for the camera and it works?
Old 01-20-2014, 08:09 PM   #14
VKnid
My Ride: 2002 330i
Yep. The only wire connected to the head unit is the yellow RCA into the green input cable. I was surprised it worked. The cool thing is that it will turn on as soon as I start the car and put it in reverse. You don't have to wait for the system to boot up.
Old 01-21-2014, 02:51 AM   #15
dragondrpr
My Ride: 03 325xi
Sold out ?
dragondrpr is offline   Reply With Quote
Old 01-21-2014, 08:02 AM   #16
jaffaz32
My Ride: E46 318i
WOLFN8TR Can you test an ipod and iphone if possible.
Does the unit charge the ipod and iphone now as apparently the D5150 didnt have enough power to charge and play devices. it only played them which means you can't leave a ipod permanently connected as you had to remove it to charge.
jaffaz32 is offline   Reply With Quote
Old 01-21-2014, 01:21 PM   #17
VKnid
My Ride: 2002 330i
I have an old iPhone 3GS connected and it charges, it also charges my 4S. I tried my wife's 5S with the lightening adapter. It played, started charging, then tried to connect to bluetooth, and stopped charging. I also go a weird error message (with Chinese characters) and it kept restarting itself until I pressed the reset button. So I would think that any of the iPods or iPhones with the old 32 pin connector should work.
Old 01-21-2014, 01:29 PM   #18
mole51
My Ride: 2004 BMW E46 M3
VKnid, I think I commented on your YouTube video yesterday and today under the name 'moleBRUV' (please don't ask, no idea why I chose that username :p). I'm worried about that comment above about the screen glare as I have a convertible and if you're having trouble seeing the screen in your coupe just under normal day light, that makes me worry about how easy it is to see in bright sunshine with the roof down (the OEM 16:9 navigation screen can easily be seen even if sunlight is blasted onto it as it uses transflective LCD technology).
mole51 is offline   Reply With Quote
Old 01-21-2014, 01:40 PM   #19
VKnid
My Ride: 2002 330i
mole51, you probably mean WOLFN8TR. He's got a coupe and did the above video. I have a sedan with untinted windows and the glare is pretty bad especially when the sun directly hits the dashboard. I imagine it would be nearly impossible to read in a convertible with the top down on a sunny day.
Old 01-21-2014, 02:30 PM   #20
mole51
Sorry, I would have meant him (very tired atm with work). I suppose the glare isn't too big an issue because I know I won't be using the navigation app much as I always use my phone, and source, volume etc can be controlled with the hard buttons. But from the pictures I've seen it looks like its a fairly bright screen, so I presume you two only mean the screen is impossible to see when the sun directly hits the screen? Other than that it's okay under a normal slightly bright day?
I live in the UK and would have absolutely no second thoughts if I knew I was ordering from a UK supplier with decent and fast customer after-sales support, but from everything I've read their customer service sounds rubbish so I'm worried about. I presume as you've upgraded from the older Eonon units you guys see the support as pretty good?
bluetooth, dvd, e46, navigation, touch screen
