Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 145 votes, 5.00 average. Display Modes
Old 01-24-2014, 06:34 AM   #41
jaffaz32
My Ride: E46 318i
Originally Posted by Anjoz View Post
First of all thank you for the post! Your old post on the install and this one will be a lot of help when I start to install mine!! I have been lurking around the forum, reading as much as I can on installs for last few days. I'm almost convinced this works and just about to order it. I'm still confused on two things:
1) I have a 2003 BMW 325i with Business CD now. To reposition the climate control to sun glass holder box do I need to buy anything or would it just sit in once I remove the glass holder box out of the frame?
2) The antenna connector you bought off of amazon, do you know if that will work with my car model? Coz when I tried on amazon it said not compatible!
I'm not the best person to answer this but from what I have been reading...
You will have to buy a relocation kit for the heater controls, sold by BMW but you can buy it else where. see here for reference and numbers.
http://www.mybimmer.net/howtos.htm
the antenna appears to be a Universal part, I looked it up on their website to check this also.
the other thing you need to consider which is not clear is... You may also need a wire extension harness. I'm not sure if we need this with the GM but with the previous D5150 I believe you did.
jaffaz32 is offline   Reply With Quote
Old 01-24-2014, 07:33 AM   #42
daki_bmw
My Ride: 330Ci
Originally Posted by brewer90 View Post
Mine behaves the same way then. It would be nice if it kept up when powered down but it isn't that big a deal since it syncs up within a couple of minutes upon startup.
If you have gps sync option checked and gps software started (for example Igo, or Garmin, or whatever...), unit's clock will freeze, right?
daki_bmw is offline   Reply With Quote
Old 01-24-2014, 08:51 AM   #43
brewer90
My Ride: 06 330Ci ZHP
I don't have my gps software installed yet but will check that when I do.
brewer90 is offline   Reply With Quote
Old 01-24-2014, 05:38 PM   #44
rocksonrocks
My Ride: 325i
This is what happens to me. However after I did an "Initialize" in the Settings I am able set the clock without sync and in 24 hr mode and it now keeps time with the car off. If I try the am pm clock it will stay in whichever one I set . The time will be correct but it always says am or pm......... However the clock still stops if I use sync mode for the clock and start the Igo Primo nav app.
rocksonrocks is offline   Reply With Quote
Old 01-24-2014, 06:06 PM   #45
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
My clock is keeping correct time with GPS Sync'd and GMT-7. When I start Igo the clock on the Nav is correct but on the main screen it's off. When you close Igo and go back to the main screen the clock corrects itself within 1 minute. I'm using Igo Primo 2.4.
Welcome and glad to help.
If you want a nice clean install go with the AC relocation bracket, links to buy one are on the first page of the Eonon D5150 Install thread.
I would use the Antenna Adapter listed on the first page of this thread I got from Amazon. For the best reception that one works the best and it's $13. Don't trust Amazon for the comparability.
Build Thread - S54 Vanos Thread
TTFS Engine/SMG Tune - SGT Headers/Sect 1/SCZA - Evolve Eventuri - Sprint Booster V2
UltraGauge - Orion V4's - CF Lip/Console/Diffuser - VIS XTS CF Hood - CSL Trunk - Valentine One - Turner 15F/12R Spacers
WOLFN8TR is offline   Reply With Quote
Old 01-24-2014, 07:33 PM   #46
Anjoz
My Ride: 325i
Thumbs Up
Again, thank you all for the replies. Really appreciate it!
Sorry about the noob question! So I have two buttons - DSC and Surround as you see in the image. So I presume I have to buy Radio mounting bracket with individual button slots with smokers package (since I have an ashtray and an LED in the tray)? I mean this one - http://www.ecstuning.com/Search/Site...30902/ES86962/
Anjoz is offline   Reply With Quote
Old 01-24-2014, 07:55 PM   #47
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
You need the other one "Single Slot". The control panel with the two buttons fits into one large slot. And yes you need the smokers package.
http://www.ecstuning.com/Search/Site...01410/ES82727/
Old 01-24-2014, 10:11 PM   #48
Anjoz
My Ride: 325i
Thank you!!!!
Old 01-25-2014, 02:08 AM   #49
daki_bmw
My Ride: 330Ci
My clock is keeping correct time with GPS Sync'd and GMT-7. When I start Igo the clock on the Nav is correct but on the main screen it's off. When you close Igo and go back to the main screen the clock corrects itself within 1 minute. I'm using Igo Primo 2.4...
Absolutely same thing here. But the thing is, I'm using gps software (Primo and Igo8...depends on my mood...I even managed to make Garmin work...) probably 90% of the time - gps is main reason for buying the unit. Igo works in the foreground OR in the background. If it's in the background, I don't have the correct time in the main screen (big clock) or in different modes (small clock). What I'm trying to say gps sync option is useless to me, altho it's working as it should.
This is really the only problem I have with the unit. And it's a small problem. I'd just love if the clock kept time like the OEM one did, when the car was off...since I know that the unit gets +12V 24/7 via the yellow cable on the main harness.
Old 01-25-2014, 07:07 AM   #50
rocksonrocks
My Ride: 325i
Have you figured out how to adjust the volume for Igo Primo? Mines pretty random compared to my source (radio or memory card). Some times nav is very quiet compared to source. If I turn up volume while nav is speaking, radio volume goes up to. Sometimes the relative volume is good but I don't know what I did differently? I tried all the adjustments in Igo and Eonon but relative volume is still random.
Old 01-25-2014, 07:50 AM   #51
daki_bmw
My Ride: 330Ci
Hmmmm, honestly I don't remember having any issues with volume. I'd have to play with the unit's volume some more... I'll tell you what I do remember - in Primo, all volume settings are maxed out (master, voice, ding, etc.) except key which is disabled (it's annoying - everytime you touch something in Primo, radio stops). Radio is around 1-2, USB same, bluetooth is around 50%, somewhere in the middle because of phone calls (I don't use A2DP...but if I did, 50% would be too loud). Very important thing is that I have GPS mix disabled in the settings. Did you try to adjust desired unit's volume while in gps mode, without sound coming out from any other source, and then go to radio, or sd, and adjust it's volume? I'm asking because I can't remember from the top of my head how volume works, but I remember what I do and I have no issues.
Old 01-25-2014, 10:06 AM   #52
jaffaz32
My Ride: E46 318i
WOLFN8TR
Thanks for your help, we both have the business cd option.
Do we need a wire extension harness?
Also I saw that it now comes with a 90 degree cable for iPod but noticed you purchased another cable as well as the amazon one. Do we need this also for the GM or have Eonon also supplied this with the GM?
Old 01-25-2014, 10:31 AM   #53
brewer90
Originally Posted by jaffaz32 View Post
WOLFN8TR
If you have the business cd then everything you need is in the box. Wolf's earlier iPod harness is no longer required. The only thing you might want is the metra antenna cable he recommends for better radio reception. The included one will work but reception is poor.
Old 01-25-2014, 11:32 AM   #54
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Do you have the D5150? On the GM5150 the time is incorrect on startup but with GPS Sync on it corrects itself within a minute. When using Nav the clock takes priority which is good for calculating time to destination. If you leave the Nav running in the background the clock on the main screen will be wrong. If you exit the Nav program (turn it off) the clock on the main screen corrects itself within a minute. Do you have the clock option on the dash readout (DIC)? I usually just use that.
Have you figured out how to adjust the volume for Igo Primo? I tried all the adjustments in Igo and Eonon but relative volume is still random.
Hmmmm, honestly I don't remember having any issues with volume. I'd have to play with the unit's volume some more... I'll tell you what I do remember - in Primo, all volume settings are maxed out. Very important thing is that I have GPS mix disabled in the settings.
If you "GPS Mix Ratio" there is a setting from 0-10, that is the ratio of sound coming from the Nav, "0" is the lowest and "10" is the loudness. If you have this feature disabled it's at it's loudest. Also there are Volume settings in the Nav as previously stated by daki_bmw.
WOLFN8TR
Welcome...
No extension harness needed, that's only if you are replacing OEM Nav.
The 90 degree iPod cable Eonon supplies will work but it does stick out a little farther than the one I used. If you use the Antenna adapter Eonon supplies you will need to trim it down so I suggest getting the Metra Antenna adapter on the 1st page. I will post up some photos on the first page showing the differences of the cables.
Old 01-25-2014, 05:59 PM   #55
Anjoz
My Ride: 325i
HU and the HVAC relocation bracket is on its way!!! About to order the antenna connector. I'm not gonna install TPMS. Even the OEM TPMS units can be a pain I hear!
Any recommendations on rear view camera? Thinking of getting this from ebay - http://www.ebay.com/itm/271313516433...84.m1438.l2649. Do I need to consider something with night vision? I see two different versions, anyone has tried any?
Old 01-25-2014, 07:10 PM   #56
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
That camera is good but the install might not be fun. From what I've heard these come in two sizes as Coupes vs Sedans fit differently. Plus the fact you are cutting the factory wiring to power the LED light. If the camera doesn't fit you will be filling and cutting to get it to fit. But this camera is the best hidden/stock option.
See page 1 for Camera Options.
Old 01-25-2014, 07:25 PM   #57
Anjoz
My Ride: 325i
Question
So I checked the sizes and it runs 72x32mm and that is what the ebay ad seems to be listing. And my existing ones seem to be made of clear plastic. That is what made me key in on this one. Someone here on the forum mentioned, the ones that say sony are good (not sure if that means the camera is made by sony and the plate is from some Chinese factory!).
Now I'm assuming this is going to pose two problems.
1) Since the lights are in a pair, when I replace one to be LED, the light colors will differ and I will have to update the other one too right?
2) You mentioned I will have to cut to wire the led - I believe I will have to cut the wire/connector on the oem one to get it out and power this?
Old 01-25-2014, 08:14 PM   #58
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
I have also heard the Sony ones are better. Installing this camera with a LED could make it look different and be an issue matching the light to the camera LED. Yes you will have to cut the light out and use the existing light wire to power the camera's LED light. Yes they are wired in series so find the light that only has two wires not four and install it there. Updated page 1 with more camera's and links.
Old 01-25-2014, 10:28 PM   #59
dragondrpr
My Ride: 03 325xi
Thumbs Up
i am sold i want one please send me a link for the discount price so i can pay it right away
$432.00 with map
dragondrpr is offline   Reply With Quote
Old 01-26-2014, 12:25 AM   #60
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Originally Posted by dragondrpr View Post
i am sold i want one please send me a link for the discount price so i can pay it right away $432.00 with map
Post in this thread that you want to get in on the group buy. Carlos from Eonon will put your name on the list. The price is $379 without the maps and approx $409 with the maps.
http://forum.e46fanatics.com/showthr...001983&page=42
bluetooth, dvd, e46, navigation, touch screen
