Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 145 votes, 5.00 average. Display Modes
Old 01-26-2014, 11:00 AM   #61
daki_bmw
My Ride: 330Ci
Originally Posted by WOLFN8TR View Post
Do you have the D5150? On the GM5150 the time is incorrect on startup but with GPS Sync on it corrects itself within a minute. When using Nav the clock takes priority which is good for calculating time to destination. If you leave the Nav running in the background the clock on the main screen will be wrong. If you exit the Nav program (turn it off) the clock on the main screen corrects itself within a minute. Do you have the clock option on the dash readout (DIC)? I usually just use that...
Yes, D5150 with "older" style UI, but everything you described, my unit does exactly the same. And, it comes down to personal preference, really. I keep my gps software running at all times, even if I change to radio or USB mode. I am used to checking the time on bussienss CD, while the OBC display shows range, or consum, or outside temp. - personal preference. That's why I'd like that the unit kept time like OEM CD unit, because you can't get satellite lock in the garage, while starting the trip. Long story short - "gps sync" doesn't "do it" for me. That's really a small issue compared to all the other positives I can say about the unit.
Funny thing - even if you cut off power completely, unit will memorise all the other things: settings, radio stations, wallpaper, volume, last mode...
daki_bmw is offline   Reply With Quote
Old 01-26-2014, 12:16 PM   #62
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Gotcha.
FYI- Eonon released the software update to get rid of the huge clock on the main screen if your interested.
Build Thread <:> S54 Vanos Thread
-TTFS Engine/SMG Tune- SGT Headers/Sect 1/SCZA- Evolve Eventuri- Sprint Booster V2-
-UltraGauge- Orion V4's- CF Lip/Console/Diffuser- VIS XTS CF Hood- LED Fogs- Valentine One- Turner 15F/12R Spacers-
WOLFN8TR is offline   Reply With Quote
Old 01-26-2014, 02:15 PM   #63
wacuna
My Ride: BMW 323i
Originally Posted by VKnid View Post
I learned a few things after installing the backup camera today.
1. I can confirm that the radio reception is much better after disconnecting the blue wire from the Eonon supplied antenna adapter.
2. This camera seems to be working well, but it was definitely not easy to fit. Requires some creative Dremel work and double sided tape to get it to fit into hole left after removing the license plate light.
Waterproof 170°Night Vision Color Car Rear View Back Up Camera for BMW E39 E46 -$18.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
3. The wiring for the camera was pretty straight forward especially using the D5150 install tread as a guide as well as this thread for the wiring: http://forum.e46fanatics.com/showpos...02&postcount=4
4. It was not necessary to connect the orange trigger wire from the back of the GM5150 into the blue/yellow wire behind the glove box (at least not with that camera getting power from the back up light in the trunk lid). This was a good thing because I could not figure out how to disconnect the wire box from above the fuse box.
5. Carlos sent me a software update that is supposed to fix the automatic A2DP on start-up issue. Haven't tried it yet. I have to get a new SD card first. Anyone confirmed that it works?
6. The clock will sync itself if you have the right timezone set and turn GPS Sync ON. Sometimes it take a minute, but it's no longer annoying.
7. Also I took the opportunity to trim down the antenna adapter while the unit was out. Don't know if they changed it from the D5150 or not, but a little trimming goes a long way towards getting the unit to fit flush.
5.- The software didn't work for me and messed up my unit which I'm sending back for replacement... so be careful...
wacuna is offline   Reply With Quote
Old 01-26-2014, 02:44 PM   #64
wacuna
My Ride: BMW 323i
Thanks for the link. Looks like I followed the update procedure correctly. Kind of disappointed as not only did the it not fix the Bluetooth issue, but now the clock is worse as the GPS now thinks it's 10 hours ahead. So it syncs to the wrong time.
It didn't work for me and messed up my unit... I'm sending it back for replacement...
Old 01-26-2014, 04:35 PM   #65
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
OK. The clock thing was my fault. It somehow switched time zones from -5 GMT to +5 GMT and I didn't catch it. That explains the 10 hour difference.
His was actually just set wrong. Sorry to here about you're unit.
Old 01-26-2014, 04:47 PM   #66
daki_bmw
My Ride: 330Ci
Gotcha.
Nah, I want/need that clock there, it's just that I want it to show correct time since the unit gets 12V 24/7 so it shouldn't be that hard to implement.
Old 01-27-2014, 04:24 PM   #67
wacuna
My Ride: BMW 323i
I just want to say that Carlos provided me with great customer support, the time difference with HK make communication slow but still I'm impress with their service... the unit is on its way back and I'm waiting for the new one to come...
Old 01-27-2014, 05:12 PM   #68
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Good to hear...
Old 01-27-2014, 05:47 PM   #69
VKnid
My Ride: 2002 330i
Same thing happened to me. Unit is now dead. I thought I would be mad about it, but it's just a car stereo. Carlos has been really good about helping. Did you send everything back? Cables, wires, remote, etc. or just the unit? I need to pack mine up and send it off ASAP.
VKnid is offline   Reply With Quote
Old 01-28-2014, 04:55 AM   #70
jaffaz32
My Ride: E46 318i
I do have a question, do these have Dab? Digital radio?
Or is there a bolt on to enable this?
In Norfolk in the UK there are only 3 stations worth flicking through and that's at the best of times.
jaffaz32 is offline   Reply With Quote
Old 01-28-2014, 04:19 PM   #71
wacuna
My Ride: BMW 323i
I just sent the unit and kept everything else...
Old 01-28-2014, 07:02 PM   #72
Jitoo
My Ride: M3 E46
Hi WOLFN8TR,
Can you give me info this product as the link below is not working.
- License Plate Light Camera, Best OEM Look -
- $20 -
Jitoo is offline   Reply With Quote
Old 01-28-2014, 08:01 PM   #73
daki_bmw
My Ride: 330Ci
Originally Posted by rocksonrocks View Post
This is what happens to me. However after I did an "Initialize" in the Settings I am able set the clock without sync and in 24 hr mode and it now keeps time with the car off. If I try the am pm clock it will stay in whichever one I set . The time will be correct but it always says am or pm......... However the clock still stops if I use sync mode for the clock and start the Igo Primo nav app.
GENIUS! After your post I "initialized" the unit for the first time, and...lo and behold - my unit keeps time with car off and auto sync off. You ROCK! \o/
Old 01-28-2014, 08:37 PM   #74
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Originally Posted by Jitoo View Post
Hi WOLFN8TR,
- $20 -
http://www.amazon.com/gp/product/B00B0L1JIU/ref=oh_details_o07_s00_i00?ie=UTF8&psc=1&tag=5336612389-20
Old 01-28-2014, 08:42 PM   #75
wallyworld
My Ride: 2003 325i 4dr sedan
This is the one I am going to go with. I know this has beem brought up before but what is the extent of the modification required to make this fit? So filling? Or some serious material removal?
Thanks!
Sent from my SPH-D710 using BimmerApp mobile app
wallyworld is offline   Reply With Quote
Old 01-28-2014, 09:11 PM   #76
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Well it depends if you have a coupe or a sedan, apparently one requires more modification than the other does. I heard installing one on a coupe requires filing down the camera housing a bit or enlarging the hole in the trunk. You also have to cut the stock light out and wire this one into it. The two lights are wired in series so remove the one with 2 wires not 4.
Old 01-28-2014, 10:38 PM   #77
rocksonrocks
My Ride: 325i
Glad I could help. That's what these forums are all about.
rocksonrocks is offline   Reply With Quote
Old 01-29-2014, 08:06 AM   #78
VKnid
My Ride: 2002 330i
Thanks!
That's the one I got for my sedan. I had to cut off the tab and clip from the sides of the camera and shave down the back as there was not enough room to just snap it in. It mounts fairly secure with double sided tape, but I still need to do some work to seal around the edges to keep water out. I used this link
for directions on doing the wiring correctly has he explains very plainly what wire goes to what. You don't need to drill any holes. Just a few cuts in the plastic of the light housing to route the video and power cables so it will still sit flush with the trunk. After that, it's relatively easy to wire the camera power to the white reverse light and run the video cable to the unit. I did not have to connect anything else to the head unit other than the yellow RCA with that camera.
Old 01-29-2014, 04:04 PM   #79
d33p
My Ride: zcp
How is the radio reception on this? My OEM Navigation reception is terrible!
Any special instructions/install/hardware if you have factory nav?
d33p is offline   Reply With Quote
Old 01-29-2014, 11:04 PM   #80
cyberlando
My Ride: 2002 M3
well for everyone who has the GM5150 what did you guys do with the two USB cords on the back of the unit?
just curious on the routing path you took it personally dont think i will need them so i left it back in the dash.
also for the Wifi antenna how do you route that and where...............i think this unit needs a DIY more than the previous one did lol
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
bluetooth, dvd, e46, navigation, touch screen
