///M3 Forum
Old 01-19-2014, 11:33 AM   #1
NicenLoW
My Ride: E46 JB AA S/C
Scanned with Peake Tool, need sense of direction
My car is dying at stop lights i scanned my codes today and im needing some help on what is causing these codes
AE-Mixture adaption cyls 1-3 (bank 1)
AF-Mixture adaption cyls 4-6 (bank 2)
90-Fuel control cyls 1-3 (bank 1)
91-Fuel Control cyls 4-6 (bank 2)
43-Intake camshaft Vanos Advanced valve
Ive replaced MAF, Fuel filter, hunted for vacuum leaks. car runs alot better since replacing the fuel filter but still dies form time to time. Car is 03.5 6spd M3 with 70k
E46 M3 AA S/C
E53 X5 3.0i
NicenLoW is offline   Reply With Quote
Old 01-19-2014, 01:37 PM   #2
NicenLoW
Update- i unplugged MAF it seems to run better unplugged. Is this indication of bad maf?
E46 M3 AA S/C
E53 X5 3.0i
Old 01-19-2014, 01:43 PM   #3
taylor192
My Ride: 2003.5 M3
The vanos issue is causing the others. The vanos issue is likely the solenoid, the solder joints crack due to vibrations. Besian Systems has a solution, if you haven't done it already do it, it is good maintenance as every solenoid will face this issue at some point.
If you clear the codes do they come back right away? If not, do they come back after a spirited ride?
If they come back right away you might have a broken tab on the exhaust cam hub. If they come back after a spirited ride, it's the vibrations of high RPMs exasperating the solder crack issue.
Sent from my Nexus 5 using BimmerApp mobile app
Old 01-19-2014, 02:32 PM   #4
NicenLoW
they dont come back right away it takes some time, i guess ill be buying the solenoid pack
E46 M3 AA S/C
E53 X5 3.0i
Old 01-19-2014, 05:51 PM   #5
taylor192
My Ride: 2003.5 M3
Go drive the piss out of your car, 7-8k shifts will probably trip the CEL right away. For $150 after core return it's good maintenance anyways.
Old 02-24-2014, 01:51 PM   #6
NicenLoW
Replaced the solenoid pack and cleaned the valve body, runs so much better! The ses light stayed off for 2 weeks, now I'm getting the same rich codes as before without any symptoms I was having before???? Maybe a bad fuel pump?
E46 M3 AA S/C
E53 X5 3.0i
Old 02-24-2014, 02:32 PM   #7
NicenLoW
Getting a slight erratic idle, 800-1000 then slight dip when I engadge clutch at redlight
E46 M3 AA S/C
E53 X5 3.0i
Old 02-25-2014, 01:28 PM   #8
NicenLoW
Is there any way to test if it's fuel pressure regulator or fuel pump?
E46 M3 AA S/C
E53 X5 3.0i
Old 02-25-2014, 02:21 PM   #9
taylor192
My Ride: 2003.5 M3
Search "idle drop". Very common, no conclusive fix.
Old 02-25-2014, 02:54 PM   #10
NicenLoW
But I'm still getting the P0172, P0175 rich bank 1 and 2 codes. I feel like it's either the fuel pressure regulator or fuel pump? Already have replaced maf, fuel filter, no vacuum leaks and just replaced solenoid pack and cleaned valve body.
E46 M3 AA S/C
E53 X5 3.0i
Old 02-25-2014, 03:56 PM   #11
taylor192
My Ride: 2003.5 M3
Then test the pressure at the fuel rail.
Old 02-25-2014, 04:03 PM   #12
NicenLoW
If incorrect pressure it's regualtor? How do you differ between regulator and pump? Won't they both cause inconsistent pressure?
E46 M3 AA S/C
E53 X5 3.0i
Old 04-16-2014, 09:26 AM   #13
NicenLoW
I replaced the fuel pressure regulator and checked my fuel pressure and it looks great, but can a fuel pump still not perform correctly? From what I've read on forums the next step is to replace the fuel pump but it seems to be putting out great pressure 68-75psi
I've already replaced
Maf
Fuel filter
Fuel pressure regulator
Hunted for vacuum leaks
Vanos solenoid pack
Cleaned icv
What should be next step?
E46 M3 AA S/C
E53 X5 3.0i
Old 04-16-2014, 11:23 AM   #14
taylor192
My Ride: 2003.5 M3
Cry.
I've read many posts from people like you who unsuccessfully hunt the idle drop by throwing every part at it. The most success seems to be getting a tune or having the adaptations reset.
I'm guessing something is just on the edge of what the ECU expects causing it to misbehave, thus why a tune fixes it cause the tune moves the edge.
Old 04-16-2014, 11:50 AM   #15
NicenLoW
Luckily I live 3 miles away from bimmerworld. I guess I need to bite bullet and have it tuned
E46 M3 AA S/C
E53 X5 3.0i
Old 04-17-2014, 01:52 PM   #16
NicenLoW
Just an update, I believe AA has found the solution to my issue. Pretty simple fix. Looks like the MAF was a little too close to blower and making it go crazy.
E46 M3 AA S/C
E53 X5 3.0i
Old 04-21-2014, 02:25 PM   #17
atrak
My Ride: 01' em three
what thats the problem? Thats kind of infuriating isnt it.. glad to see it got fixed. Better excuse for me to get a tune done.
atrak is offline   Reply With Quote
Old 04-23-2014, 10:24 AM   #18
NicenLoW
Apparently the blowers turbulence near the maf was making it go crazy. I'm waiting on an elbow for relocating maf lower into bumper so I haven't got to test it out just yet!
E46 M3 AA S/C
E53 X5 3.0i
Old 05-10-2014, 07:52 PM   #19
NicenLoW
Just an update moving the maf lower turned off the SES light and runs perfect.
E46 M3 AA S/C
E53 X5 3.0i
