///M3 Forum
Old 01-20-2014, 08:07 PM   #1
das86turbo
My Ride: GTS4 M3, 330XI, 911
Race car build: E46 M3 - ECU pin release too
So I erred on removing too much wire on my M3 E46 race car build. I need to add a few wires back into the ECU/DME circuit. I have numerous pin release tools, but none small enough to accommodate the small pins found on the multi-pin connectors that connect to the ECU. Does a tool exist, and if so where can I find one? These babies are tiny. Hoping this does the trick. I was religious in testing each circuit as I removed wires..... then I got lazy. Now back tracking. Thanks in advance.
das86turbo is offline   Reply With Quote
