Old 01-21-2014, 10:38 AM   #1
Ft1219
My Ride: BMW?
EU2 tune/flash
Is there anyone in the NC area that can EU2 flash my car? (I'm running BB Catless headers) I know there are many threads on how to DIY but I'm just not feeling comfortable/confident doing it. Can anyone help me out?
Hellrot/ 3.64 LSD/ MTech II/ Schrick Cams/ Bimmerbrakes Headers/ Highline Tuning Exhaust/ Active Autowerke Software/ TMS Pulleys/ BMW SSK/ Powerflex bushings/ DNA Rear Adjustable Control Arms/ BBS LM Wheels/ Apex Studs/ Bilstein pss9 coils/ UUC Mounts/ Sparco Seats/ Macht Schnell Brackets/ Project kics Lug Nuts/ Pirelli P Zero
Ft1219 is offline   Reply With Quote
Old 01-22-2014, 02:44 AM   #2
Snipez4664
My Ride: '00 328i
not trying to hijack the thread, but if someone in the mid atlantic area able to do this, i'm looking for the same thing. thanks
Questions about M3 subframe/LSD swap in your non-M? Feel free to PM me...i has all teh answers
Snipez4664 is offline   Reply With Quote
Old 01-24-2014, 07:57 PM   #3
Ft1219
My Ride: BMW?
Got it tuned by CESmotorsports in Charlotte. Problem solved
Old 01-24-2014, 08:08 PM   #4
Sedan Hussein
My Ride: e46
How much?
Sedan Hussein is offline   Reply With Quote
Old 01-25-2014, 01:12 PM   #5
///Mvious
My Ride: E46 330
Originally Posted by sedan hussein View Post
how much?
+1
///Mvious is offline   Reply With Quote
Old 01-25-2014, 01:44 PM   #6
Ft1219
My Ride: BMW?
$704.10.
Old 01-25-2014, 05:03 PM   #7
trentcdrums
My Ride: BMW 323i Sedan
^ Lol, absolute fail. EU2 tune isn't even $50...
Old 01-25-2014, 08:51 PM   #8
Ft1219
My Ride: BMW?
It was a AA tune with rear o2 sensor delete! Dumbass
Old 01-25-2014, 08:56 PM   #9
trentcdrums
Congratz, fix your title den dumaz
Old 01-25-2014, 09:14 PM   #10
Ft1219
My Ride: BMW?
Go on somewhere.
Old 01-26-2014, 12:34 AM   #11
Snipez4664
My Ride: '00 328i
pretty expensive, but to be fair there are only a few power mods on e46 non-ms before going FI, and a proper tune can make the power delivery better in many areas, not just power. Do you feel a difference? did they happen to give you a before and after dyno? i assume for $704 it was a custom dyno tune?
Old 02-05-2014, 12:55 PM   #12
vlcmstnsct
My Ride: 2002 E46 330i
I am in Christiansburg, VA...I flashed my personal vehicle with EU2 and would be willing to do someone else's as well as update any modules on the car. 2.5 hours from Charlotte, NC.
Regards,
Aaron
2002 330i 5spd
VIR Oktoberfast 2013
vlcmstnsct is offline   Reply With Quote
Old 02-05-2014, 04:44 PM   #13
trentcdrums
Are you constantly using 93? Or lower. I usually use 89 every fill up.
Old 02-05-2014, 05:20 PM   #14
Ft1219
My Ride: BMW?
Why would you run 89? BMW recommends premium for a reason.. I use 93 every time I fill up
Old 02-05-2014, 07:33 PM   #15
trentcdrums
I never felt a difference with 93 vs 89.
Old 02-06-2014, 01:36 AM   #16
vlcmstnsct
I have never put anything but 93 octane in my BMW; our cars were designed for high octane as they are performance oriented. A lot of people do NOT know/understand running a lower octane fuel than that which is required by BMW and other makers (perhaps in an effort to save $) is saving you very little money, nothing at all, or even possibly costing you more. BMW literally designs all of their motors to run on 91 octane. Fact.
The lower octane fuel burns faster and is more prone to detonation and thus detonation will occur (knocking). The DME (ECU), senses the knocking and starts pulling timing and dumping fuel to prevent further knocking = LOSS OF POWER AND FUEL EFFICIENCY. As time progresses, the DME will learn and adjust the different values to run optimally on the low octane gasoline BUT still at a loss of power/MPG. Are there big losses?..NO. If your E46 is N/A (naturally aspirated) you shouldn't lose but maybe a few ponies definitely <10 BUT if you've got F/I (forced induction) than you'd see larger losses. There are other factors (ambient temp, driving habits, etc.) which would increase/decrease knocking associated with using lower octane fuel and therefore also affect losses.
If your driving a BMW, with almost complete certainty I can tell you lower octane fuel is not going to hurt your motor or anything else...except your ego when you get spanked by a Prius (kidding). BMW's have really good knock sensors/DME/software and the DME has the ability to completely adjust what it needs to, to run optimally. This is not the case for all car manufacturers. Example: some GM vehicles can not fully adjust the fuel and ignition timing to completely stop detonation from crap gasoline and though it's minimal, it'll slowly destroy the motor.
Regards,
Aaron
2002 330i 5spd
Old 02-06-2014, 05:18 AM   #17
trentcdrums
Interesting.. I've got some change to come
Old 02-06-2014, 05:33 AM   #18
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
It's not about "feeling" a difference. It's better for your engine. You wouldn't "feel" a difference if you put vegetable oil in your engine instead of motor oil. But I'm willing to bet we both know that your engine would definitely be worse because of it.
Old 02-06-2014, 05:48 AM   #19
///Mvious
My Ride: E46 330
I might have to take you up on this in the Spring...I'm running headers and removed the SAP...I'm assuming there is little to no risk of it not running or running right?...of course I'd be driving it there and would like to drive it back
Old 02-06-2014, 10:46 AM   #20
daniel_f.
My Ride: 330iC
Just keep in mind that an ecu brick can happen. in this case its not very likely your driving it back
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
