E46 Convertible
Old 01-22-2014, 10:51 AM   #1
Shaun345
My Ride: 318Ci 345Ci custom
top moves slower and slower
my top moves slower and slower with every use, i am banking on the motor. can someone just reassure me my thought are in the right area.... plz help
Shaun345 is offline   Reply With Quote
Old 01-22-2014, 11:32 AM   #2
AquilaBMW
My Ride: 325i Convertible
Probably not the motor, read the two posties up top and review the symptoms and solutions.
AquilaBMW is offline   Reply With Quote
Old 01-22-2014, 11:57 AM   #3
taylor192
My Ride: 2003.5 M3
Check the fluid level with the top down. Slower operation means the system is taking more effort to pressurize, which probably means you have a fluid leak. The pump is behind the carpet on the left side of the trunk.
If there is sufficient fluid, then it is the pump.
Old 01-22-2014, 12:05 PM   #4
Shaun345
thanks guys, i have been thru the posties and from i got the car i had to change the locks and everything worked fine, aaannndddd it got slower, and slower and it got to the point where i have to assist it and if i dont it stalls and i have to shut down and try again. the pump takes a few seconds to hear it has load on it (pressurized) thats what makes me think its the motor. but will check fluid levels and for leaks. thanks for the replies
Old 01-22-2014, 03:19 PM   #5
pauljcl
My Ride: 2005 330cic
To the extent possible, I lubricate the hinges and connectors once a year, with (very) small amounts of lubricating oil that I then wipe off. I noticed a difference after the first time - I had never done it for five years. Can't hurt.
pauljcl is offline   Reply With Quote
Old 01-22-2014, 03:39 PM   #6
Shaun345
Will di thanks for the advice
Old 01-22-2014, 06:46 PM   #7
AquilaBMW
Whoops.... guess I was wrong. Maybe I should check my pump too :-)
Old 01-28-2014, 05:36 PM   #8
Phoenix330ci
My Ride: 04 330Ci Convertible
out of curiosity....how slow is slow. I have never officially timed mine except for counting 1..2..3..out loud to see how long it takes so I know if I have time to drop the top at a light or not. I get a count of like 24-26 for each cycle, down/up.
Phoenix330ci is offline   Reply With Quote
Old 01-28-2014, 05:53 PM   #9
Shaun345
Once it starts to open now the top front lifts up as usual, then the back to open the back lid. It times out there. Its so weak now i have to get someone to press the button and i assist it in every move. The hydrolics are shot. I will try the motor out of mu wifes. If that works well off to buy a new pump assybly i go
Old 01-28-2014, 08:05 PM   #10
taylor192
My Ride: 2003.5 M3
Did you check the fluid level yet?
Sent from my Nexus 5 using BimmerApp mobile app
Old 01-28-2014, 08:28 PM   #11
Shaun345
Its been something that i been meaning to do but have been slacking, but thanks. For the reminder. Its like everytime i go to do it i completly forget and just sit there and listen to music and forget. Will check tomorrow evening and post the findings. I know if its low i hv a leak, them i am on a hunt.
