Old 01-23-2014, 11:44 PM   #1
rojeho
My Ride: 03 330i, 04 325Ci
OEM Xe low beam odd intermittent behavior
I'll follow the steps here from another post, but wanted to put this out to see if there is a plausible explanation for this.
Day #1, start car at night in the dark, passenger side low beam doesn't turn on and triggers the dash display. Made three stops and each time the bulb was out.
Day #2 - pull the car into the garage in daylight, but the lights turn on. Everything is on - taillights, dash amber lighting, headlights - both of them.
Day #3 - again start the car in the dark and the same low beam won't turn on.
Why is it that when the car auto-turned on the headlights did the low beam passenger work but when the car is started in the nighttime darkness it won't turn on?
2004 325Ci / 5MT
2003 330i / 5MT
rojeho is offline   Reply With Quote
Old 01-24-2014, 11:45 PM   #2
rojeho
Swapped bulbs, no change, passenger side still out. Swapped ballasts, powered on, the driver side worked as it has been, and the passenger side was dark for about 30 seconds and then came to life. That points to the passenger side ignitor being weak/faulty, doesn't it?
2004 325Ci / 5MT
2003 330i / 5MT
Old 01-27-2014, 09:29 PM   #3
Dluxx88
My Ride: '05 325ci
ever find anything more with this? having kind of the same problem. water leaked down and shorted my pass side ballast. replaced ballast, and now drivers side light wont turn on. if i unplug the xeon (gray connector on headlight)on the PASSENGER side, the drivers side will then turn on, plug back in pass light, everythings ok (dash light for drivers side bulb on). i dont understand. is this signs of an ailing lcm? or like you said, a failing ignitor?
Dluxx88 is offline   Reply With Quote
Old 01-27-2014, 09:58 PM   #4
rojeho
Neither of my local dealers stocked the ignitor (of course not, the price quoted was within a few dollars of mail order...) so I am waiting for one to arrive and I'll install in next weekend.
2004 325Ci / 5MT
2003 330i / 5MT
Old 01-29-2014, 04:48 PM   #5
daselko
My Ride: 01 330i
Where did you order the part? Looking for ballast and ignitor from a place other than dealer. They wanted about $450 for each and that's with a discount from my buddy who works there.
daselko is offline   Reply With Quote
