330Ci M-Sport with Style 68 with spacers? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 01-24-2014, 05:57 AM   #1
Carrera
My Ride: 330Ci M-Sport
A lot of threads and a lot of questions but I still couldn't find any good answers...
So the question is what is the correct spacer set up for a 330Ci M-Sport with staggered Style 68 wheels?
- 7.5x17" ET 41 Front with 225/45/17 tyres, spacers xx mm?
- 8.5x17" ET 50 Rear with 245/40717 tyres, spacers xx mm?
And no, I do not intend to roll the fenders nor to use narrower tyres at the rear.
Thanks in advance!
Carrera is offline   Reply With Quote
Old 01-24-2014, 11:17 AM   #2
mr ilia
My Ride: 2004 BMW 325i 5spd
Check out this thread:
http://forum.e46fanatics.com/showthr...ight=68+spacer
---- My Beemer history ----
2004 BMW 325i sedan - Schwarz II
1998 BMW 323i coupe - Lazurblau
2004 BMW 325ci - Sapphire Black
1991 BMW 318i sedan - Lazurblau
2001 BMW 330i sedan (Auto) - Japanrot
http://forum.e46fanatics.com/signaturepics/sigpic288773_1.gif
mr ilia is offline   Reply With Quote
Old 01-24-2014, 12:34 PM   #3
Carrera
Yep thanks. Been through that thread quite a few times. Its great stuff if you wanna go with 225 tyres in the rear but what if you wanna stick with the standard 245 rear tyres?
Sponsored Links
Advertisement
Old 01-24-2014, 12:37 PM   #4
WDE46
My Ride: '13 128i STX
Ask Mango. He has spacers and stock tire sizes.
Old 01-24-2014, 12:42 PM   #5
330ism
My Ride: 2004 330I ZHP
If you measure the distance between the outer side of the wheel and the inside of fender with a straight edge it will give you that answer. Just subtract a couple of mm's for suspension travel
330ism is offline   Reply With Quote
Old 01-24-2014, 12:47 PM   #6
My Ride: Lexus
On a sedan, 15mm spacers front and 12.5mm spacers in back is safe. I used to have 15mm in the back but as soon as installed M3 balljoints with the same alignment specs (camber) the 15mm started rubbing. so I swapped front and rear. Did not want to roll. The rubbing was very minor. Maybe 1 or 2mm off. All it did was rub dirt off.
So on a coupe that has a wider rear body (very slightly) i'd say 15s would be safe both in front and rear. thats w/ stock 68s and stock tire sizes
Old 01-24-2014, 03:07 PM   #7
Carrera
Thanks Mango! That was my assumption as well, thanks for confirming!
Old 01-24-2014, 03:13 PM   #8
My Ride: Lexus
this is how your front will look with 12.5mm:
rear is hard to compare w/ sedan vs. coupe but you'll get an idea.
Old 01-24-2014, 05:19 PM   #9
Carrera
Great! Looks damn good!
Old 01-24-2014, 05:56 PM   #10
Blueandwhite85
My Ride: E46
Thanks Mango, you answered a question I never asked.
Blueandwhite85 is offline   Reply With Quote
Old 01-24-2014, 06:56 PM   #11
mikeetastic
My Ride: lots of 3
i'll ask too..
mine is a 325i wagon running style 68mm - what spacers can you recommend and where to buy? do i need to change my lug nuts too?
TIA
edit: running hancook 245 back and 225 front i think.
mikeetastic is offline   Reply With Quote
Old 01-24-2014, 07:06 PM   #12
WDE46
You need new lug bolts with any significantly sized spacers (> 5mm probably).
Old 01-24-2014, 07:20 PM   #13
jdstrickland
My Ride: '94 325iC & '00 323i
What makes you think spacers are needed at all?
Yes, I get that you want them, but they are not needed.
Old 01-24-2014, 07:27 PM   #14
WDE46
Who said they were needed?
Old 01-25-2014, 07:25 AM   #15
Carrera
Originally Posted by mikeetastic View Post
i'll ask too..
TIA
It depends on the type and width of the spacer you wan't to go with whether you need new bolts or not. Anything below 15mm will be spacers that fit between the wheel and hub and they always require longer wheel bolts. If you go with 15mm+ you have a choice of spacer types. The most common is the one where the spacer goes between the wheel and the hub and you replace your existing bolts with longer ones. The other option is to use spacers that bolt to the hub with special bolts (included in the set) and provide new threaded holes for the existing wheel bolts.
There are numerous good choices for spacers. One of the most well known and respected is H&R which you can buy through most tuning shops. I'm sure your US forum buddies can advice where to buy them. I went with 15mm bolt on spacers. They are German made by FK Automotive. However, I don't think they sell their products in the States.
Yep, there is no need as such to use spacers with Style 68 wheels. It's all about looks and perhaps a slight edge on the drive feel on track
Old 01-25-2014, 12:10 PM   #16
WDE46
Nobody said they were needed. We all know they're primarily for looks.
Old 09-15-2016, 12:51 AM   #17
YoitsTmac
My Ride: 328Ci
Has anyone been ballsy enough to install 255 on rear style 68's installed the front? I'm currently looking at this sheet and thinking I might need spacers. Unfamiliar with spacers and seem like more trouble than I'd like to get into
YoitsTmac is offline   Reply With Quote
Old 09-15-2016, 01:05 AM   #18
WDE46
I mean 255 isn't going to be an issue. Plenty of people have the rear 68s on the front for a square setup. Most ate using 245s but 255 isn't too wide for the wheel and I doubt it rubs.
Old 09-15-2016, 01:10 AM   #19
YoitsTmac
My Ride: 328Ci
Alright fair enough...hopefully they'll still be available! I'm sure they are
