Sponsored by BimmerWorld
Old 01-24-2014, 11:44 AM   #1
Dazza335iC
My Ride: '02 330Ci, '92 345iC
Rear diff bushing removal Q
I have a crack in the rear diff bushing...
It'll need to be replaced sooner rather than later and everything I read says it's a bitch of a job without special tools and lots of time. But does it have to be?
I started thinking: On e30s it's super easy. Unbolt rear diff cover, unbolt rear diff bushing, and voila! Out it comes in one small and easy to manage piece. 5 minutes with a press and you've got the old bushing out, new one in, and you're ready to bolt the cover/bushing back in the car.
It looks possible, but I must be missing something... If it's this easy everyone would be doing it this way, right? Or did I just stumble on some kind of holy grail
edit: nevermind. Upon further inspection it appears the bushing carrier/mount is attached to the subframe and not the diff cover... D'oh!
Dazza335iC is offline   Reply With Quote
Old 01-24-2014, 02:52 PM   #2
Phoenix330ci
My Ride: 04 330Ci Convertible
Exactly!
The tool makes the job a lot easier and this one only cost $125. Allows it to be removed and pressed in while the sub frame is on the car. I have read threads where people did this and that it seemed it took them hours trying to remove and install without the specific tool. It all is a factor of time vs. money. I like (for the most part) working on my car but enjoy free time on the weekends. Also while you are thinking of it get the Myle HD bushing, supposed to last longer.
Phoenix330ci is offline   Reply With Quote
Old 01-24-2014, 03:48 PM   #3
Dazza335iC
Do you have a link to said tool?
edit: nvm, found it in your reply to another thread!
Old 01-24-2014, 03:51 PM   #4
mr ilia
My Ride: 2004 BMW 325i 5spd
Removing the bushing without special tool is easy, the hard part is to press it in. But you can always use Powerflex bushing poly bushing, it does not need any special tools to mount.
---- My Beemer history ----
2004 BMW 325i sedan - Schwarz II
1998 BMW 323i coupe - Lazurblau
2004 BMW 325ci - Sapphire Black
1991 BMW 318i sedan - Lazurblau
2001 BMW 330i sedan (Auto) - Japanrot
http://forum.e46fanatics.com/signaturepics/sigpic288773_1.gif
mr ilia is offline   Reply With Quote
Old 01-24-2014, 05:18 PM   #5
Tangent_
My Ride: '01 330i, '11 Z435i
I wish it was that easy on an E46. I read quite a few horror stories about getting the old bushing out and some problems getting new ones in without the proper tool. Some people didn't have that trouble, but considering how easy the proper tool amde it I can't recommend it enough. I rented the tool and it made the actual bushing removal/replacement by far the easiest part of the entire job. The job itself really isn't difficult, just time-consuming. The hardest part was getting the diff back in. I rested it on a jack and had somebody help with pushing the jack forward and back while lifting or lowering it as I wrestled the diff into place.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 01-24-2014, 09:38 PM   #6
Phoenix330ci
Agree......it took me a couple hours of removing the necessary parts and the differential, especially since you need to have someone put the tranny back and forth from park to neutral to spin the drive shaft to remove the differential bolts. I had the bushing in and out I think in ten minutes. I did this job over two days under the car without a lift. One day I took it all out and changed the bushings. Then quit. The next day installed it all back in. I think the dealer wanted something like $1,900 for the job. Between tool and parts, I think I was at $175-$200.
The tool for this job is really not that much, $125 and worth every penny, and no struggle. My dad was there and could not believe how little time that part took compared to all the other things you had to do.
Old 01-26-2014, 12:53 AM   #7
Dazza335iC
huh, I was under the impression the tool allowed for r&r of the bushing without the ned for pulling the diff. Sounds like I was wrong?
Old 01-27-2014, 01:08 PM   #8
mr ilia
This is what I want to try doing when it warms up up a little bit here.
To me it looks like you can do the rear bushing only with out taking the diff out.
I will see if this is possible when i get my hands on it.
Old 01-27-2014, 01:56 PM   #9
Dazza335iC
Thanks! Can't wait to here if it's possible!
Old 01-28-2014, 11:43 AM   #10
Phoenix330ci
Not possible. Here check out this thread. See the differential picture about mid way down.
http://forum.e46fanatics.com/showthr...ff+bushing+diy
The bracket that connects to the bushing is cast into the differential cover. To get the bushing out you need to pull the bushing out of it's bracket on the sub frame towards the passengers side of the car or towards the differential. You can't just unbolt it and pull it out from the drivers side. There is no room for the tool to do that.
Old 01-28-2014, 12:05 PM   #11
Dazza335iC
Can't the diff cover be removed in order to make room for the tool? Or is there something preventing it from being removed while the diff is still installed in the car?
Old 01-28-2014, 06:08 PM   #12
Phoenix330ci
I don't think you can get to the top bolts holding the cover on when it is still in the car, I'm sure someone on here thought of it or tried. I'll let you know if I find someone that tried that, I don't recall anyone doing it this way.
My car was over at the dealer for some other dealer related item and of course they shop the car and find other things. The original quote said they would have to remove the differential.
Old 01-29-2014, 10:44 AM   #13
mr ilia
No, one of the diff cover bolts is blocked by a unibody of the car.
Old 01-29-2014, 02:44 PM   #14
Tangent_
Exactly the experience I had, except I rented the tool from a member on here for $40 instead of buying it. :p
And there really is no easier way to do this unfortunately. There's just not enough clearance between the body, the diff, and the subframe.
