Old 01-24-2014, 12:35 PM   #1
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
Buffer Recommendations
Can I find a good one for under $50?
How useful are these things? I have no experience
JetBlackE46 is offline   Reply With Quote
Old 01-24-2014, 10:44 PM   #2
e46hellrot
My Ride: e46
here. http://www.autogeek.net/porter-cable-7424xp.html
e46hellrot is offline   Reply With Quote
Old 01-27-2014, 08:00 PM   #3
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
Hi JetBlack,
It's very hard to find a good polisher for $50 or under, even if it's a used Porter Cable 7424 random orbital. As mentioned, the Porter Cable 7424xp is a great starter unit, especially when paired with 5.5" pads. We have some pre-made kits available, such as the Porter Cable 7424XP 5.5" Starter Kit, but I'd be more than happy to put together a custom kit for you with a couple polishes and appropriate pads.
To further answer your questions, the Porter Cable 7424xp polisher is very useful because it speeds up any paint polishing compared to doing it by hand, but even more so because it can accomplish much better results than you could ever get by hand.
You're basically looking at obtaining the following in order to properly polish your paint:
- A polisher such as the PC 7424XP
- 3-4 different types of pads and probably anywhere from 3-6 of each type, depending on your car size (I prefer 5.5" foam pads as they work really well with the PC... they're large enough to make quick work of polishing and small enough to correct swirl marks and other defects really well)
- 2-4 different polishes that work well with your paint (for jet black you usually need 3 different polishes as it can be very finicky so you want to be prepared)
- 10-20 microfiber towels for removing polish residue
Hope that answers your question and as I said, if you'd like I'll be more than happy to put together a kit for you.
Thanks!
Ivan @ DI
Old 01-27-2014, 08:09 PM   #4
crazyafghanguy
My Ride: E46 M3
i used this. worked good for the price. u can also get a 20% off coupon make it cheaper. its not that hard, just time consuming
http://www.harborfreight.com/6-in-va...her-69924.html
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
Street Edge Coilovers
ZCP Brake Upgrade
LED Tail Lights
crazyafghanguy is offline   Reply With Quote
Old 01-28-2014, 12:27 AM   #5
JetBlackE46
Modded
Originally Posted by Greg@DetailedImage.com View Post
Hi JetBlack,
Thanks!
Ivan @ DI
Thanks Ivan!
How much of a difference does a polisher make as compared to hand polishing? Will it make my paint really glossy? My paint is in very good condition now, I just want it to be shinnier. I'm look for the deep dark wet look.
Thanks!
Old 02-26-2014, 09:12 PM   #6
Thanks Ivan!
Thanks!
No clue how I missed this post, I apologize for the slow response.
The difference in machine vs hand polishing is huge. Aside from the obvious ease of use and quicker results, the polisher is able to better level the paint and remove more defects. I'm not sure about the situation of your paint at present in terms of swirl marks or other paint defects, but the best way to make paint shinier is to correct these defects and let the actual color come through. This can be done somewhat easily with a polisher. Hope that explains it and again sorry about the slow reply.
Ivan @ DI
Old 03-16-2014, 08:16 PM   #7
mastercraft1990
My Ride: 2002 330ci
I'm going to look at one at the one at Harbor Freight, have read some good reviews on them, around 60.00. Not bad for a couple times a year and for 9.00 you can get a 2 year extended warranty.
mastercraft1990 is offline   Reply With Quote
Old 03-20-2014, 09:16 PM   #8
SilvaBimma
My Ride: 330Xi
HF isnt bad for the money especially if you use it once a year.
SilvaBimma is offline   Reply With Quote
Old 03-26-2014, 02:44 AM   #9
Marion Haggard
Banned User
I have Honda Hybrid and mostly i wash my car myself. I used PKC0VC Car Polisher 6" for my my car. It's very cheap i get this only $18. It's cheap and perfect for any car. I saw a car dealer used this machine for their cars shining. So that is the reason i get this machine and it's working very well.
Marion Haggard is offline   Reply With Quote
