Old 01-24-2014, 07:03 PM   #1
Noxas
My Ride: 2002 325xi
Facelift vs non facelift headlights? Help please!
Hi guys so my e46 facelifted has halogens. I've been told however that pre facelifted headlights will fit; so id like to swap in some xenons... Is this true? Someone said all I had to do was change the lenses but I'm still a little confused. Are there any diy if this is possible?
Noxas is offline   Reply With Quote
Old 01-24-2014, 07:09 PM   #2
nike001
My Ride: Fergo
Not sure if pre-facelift sedan lights swap.. ( don't think they do) but pre-facelift coupe lights do swap over to facelift sedans. The pre-facelift sedan lights aren't anything worth swapping over IMO, they're uglier and aren't bi-xenon.
To swap pre-facelift coupe (or M3) headlights, you need the AL mounting bracket below the headlight. After that, just disassemble the new-to-you xenon light and take off the outer lens and inner bezel & swap your sedan bezel & outer lens.
2015 M235i 6MT
nike001 is offline   Reply With Quote
Old 01-24-2014, 07:36 PM   #3
WDE46
My Ride: 2004 330Ci OBM
Retrofit some bixenon projectors into your halogen bowls. Find user Solidjake, look at his signature, and follow his retrofitting guide. It's good and he got great results. It'll probably cost you ~$350-$400, which is much less than OE bixenons will cost you. The E46 sedan headlights are very easy to work with too.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 01-24-2014, 08:59 PM   #4
Noxas
My Ride: 2002 325xi
Aren't bixenon roughly going for 500? I was honestly just lookin at regular xenons. Someone was telling me you could swap directly the sedan headlights which I was confused about considering everything seems differentp
Old 01-24-2014, 09:07 PM   #5
Noxas
My Ride: 2002 325xi
As well doesn't bixenon require extra wiring? That's what I was told; that it wasn't a plug and play
Old 01-25-2014, 09:05 AM   #6
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
Obviously. HID's have ballasts.
Cavi Mike is offline   Reply With Quote
Old 01-25-2014, 12:08 PM   #7
WDE46
Only a little. You can either add a pin to the LCM connector and run a wire, or you can tap the high beam with a splitter and run that to the bixenon shutter.
Do more reading on this before you buy please. There's a lot to know. Clearly you need to do more research first.
Old 01-25-2014, 12:08 PM   #8
WDE46
They plug right into our stock connectors.
