Old 01-25-2014, 01:31 PM   #1
wrdriggs
My Ride: $1,000 02 BMW 325xi
LED Interior Problems.. Wagon
So I recently purchased a whole bunch of LEDs off superbrightleds.com. I purchased regular non can-bus led's. I installed them all and I am having a few issues -
1.) The floor lighting does not work as well as the center map light. Once the car has been sitting, I can push the center map light and you can see the floor lights turn on for a brief second and then turn back off. If I try to hit it again, nothing will happen. The rear map lights work both left and right, but the center one does not work either. The other LEDs that I installed - rear trunk, glove box, mirror lights all work perfectly. Do I need to repalce all the interior bulbs with can-bus leds? or is there just certain ones?
2.) The License place lights work all the time as they should, but when the car is turned off, they will stay dimmly lit for a few minutes before turning off completly. I think the fix for this is to just get a can-bus leds, but really isnt an issue since they work fine and are not killing the battery.
wrdriggs is offline   Reply With Quote
Old 01-26-2014, 08:58 AM   #2
wrdriggs
Bump ttt
Old 01-26-2014, 10:03 AM   #3
Phrygian
My Ride: 2000 323i
Did you not read about the issues with LEDs in these cars beforehand? All of the lights that come on automatically (the dome, footwell, and rear courtesy lights) need to be canbus types, or you'll need to install a resistor in parallel with the circuit to trick the LCM.
Phrygian is offline   Reply With Quote
Old 01-26-2014, 11:06 AM   #4
jmillsner
My Ride: 330Ci 6 Spd, 335Cic
this ^. you will need a resistor (or is it a capacitor?) to make those LEDs stay lit. i believe its because LEDs draw so little power that the car doesn't think they're there or something like that
jmillsner is offline   Reply With Quote
Old 01-26-2014, 12:56 PM   #5
Phrygian
My Ride: 2000 323i
Just a resistor is needed. If the LEDs come on for a second and then go off, the LCM isn't sensing enough resistance so it shuts down the circuit. There's plenty of info on this board about how to get around that.
I should also mention that some of the non canbus LEDs are polarized. So if you have some bulbs that are not flashing at all, they may be installed backwards.
Sent from my Incredible 4G LTE using BimmerApp mobile app
