E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 4.67 average. Display Modes
Old 03-05-2014, 05:08 PM   #61
zachotaco
My Ride: 325xiT
Originally Posted by h2obimmer View Post
Had to fix this UGLY A$$ woodgrain trim. I **** woodgrain trim...looks so out of place in this car.
Plasti-Dip Aluminum looks so damn good
very impressed with the quality
I know a lot of people think plasti-dip is cheap and a waste but i've used it for wheels and trim and other things and have been very pleased with it.
btw, the cracks were in the trim and the plasti-dip didn;t cover em
Very cool idea, looks really good. Was it pretty easy to figure out how to take out the interior panels? I want to do the same
zachotaco is offline   Reply With Quote
Old 03-06-2014, 11:02 AM   #62
SamDoe1
My Ride: 4cyl of fury
^ They just pop off. Use a trim pry bar and take them out. Make sure you replace the red things that hold them in when you put them back though.
Old 03-06-2014, 01:45 PM   #63
h2obimmer
My Ride: 2005 M3, 2002 XiT
yeah it's easy to do but go slowly b/c if you break off the spikes on the back of the trim it'll never fit right again.
h2obimmer is offline   Reply With Quote
Old 03-06-2014, 03:11 PM   #64
philliplong
My Ride: 2002 325CI
I did it too quick and so I just glued the plastic brackets in place with super glue and it holds fine.
philliplong is offline   Reply With Quote
Old 03-07-2014, 11:13 PM   #65
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
I am done with all the inside the car work (management and lines) but I am about to move on to the air lines and the lines for the e-Level sensors. How do I straighten the plastic lines that came all coiled in a bundle?
/_________\
O==[][]==O
Old 03-08-2014, 12:51 PM   #66
haterdan
My Ride: 325xit
the easiest way is to roll them out flat. like pretend its a wheel and roll it on the ground. if it was warmer it would be easier. those lines have like a "grain" that they follow. HURRY UP I need to see where you mount your sensors so I can do it too!
haterdan is offline   Reply With Quote
Old 03-08-2014, 03:13 PM   #67
330i ZHP
330i ZHP's Avatar
I was using a heat gun and we have one of those hot (think hot tea) water dispensers. Both worked well on making pliable for a few minutes.
/_________\
O==[][]==O
Old 03-08-2014, 08:16 PM   #68
h2obimmer
got bigger problems with stupid rusted bolts to deal with (i'll post a full update soon)
i wanna see where u mount sensors too!
heat gun sounds good if you're careful
Old 03-10-2014, 08:50 PM   #69
330i ZHP
330i ZHP's Avatar
CLICK PIC
/_________\
O==[][]==O
Old 03-11-2014, 06:57 PM   #70
haterdan
My Ride: 325xit
Tell me more
Old 03-11-2014, 07:16 PM   #71
330i ZHP
330i ZHP's Avatar
SOOOO - it turns out the Air Lift nylon lines that came from Bagriders is much easier to use. Not stiff and shiny like the air lines that came from Accuair.
So, running the lines to the front will be less of a hassle than I have been assuming.
I have been looking at 100s of other installs of the sensors and looking at my car specifically (esp the lack of room inside the inner quarter due to me having 19x11 et25 wheels.
I am going to measure the travel (hopefully later) and determine whether I am mounting the sensor to the control arm or the rear subframe.
I will take pics - I know I need to get around 2.5" of travel (not too much or the sensor will break
Dan - have you made any progress on yours?
/_________\
O==[][]==O
Old 03-11-2014, 08:01 PM   #72
haterdan
My Ride: 325xit
not really I've been at work doing all these inspections because city hall is getting antsy. so my whole kit is sitting in the garage. hopefully in the next 2 weeks I'll knock it out
Old 03-11-2014, 10:47 PM   #73
330i ZHP
330i ZHP's Avatar
More height
/_________\
O==[][]==O
Old 03-11-2014, 10:49 PM   #74
330i ZHP
330i ZHP's Avatar
lines and sensor wiring run to the front - nice and clean and hopefully no problems down the road
I did not play with the rear sensors - I let myself get distracted with getting the front ready
/_________\
O==[][]==O
Old 03-12-2014, 07:34 AM   #75
fire730
My Ride: 01 325iT - 04 Burb
I definitely want to know how the plasti-dip holds up to the abuse of being on a shift knob.
01 325iT ZSP - Koni - Hotchkis - Stoptech
01 525iT - TiAg - Koni - B&G
04 Chevy Suburban - SLP - BlackBear - Belltech
01 330Ci - parts car
16 Chevy Tahoe - Wife's Daily
fire730 is offline   Reply With Quote
Old 03-18-2014, 01:09 AM   #76
330i ZHP
330i ZHP's Avatar
rear suspension done, wheels back on and interior all back together
/_________\
O==[][]==O
Old 03-19-2014, 09:17 PM   #77
h2obimmer
oh i pulled the plasti dip off the knob a day after i did it. i picked at it too much like a scab...lol
Old 03-24-2014, 02:01 AM   #78
h2obimmer
PROGRESS!!! PROGRESS!!! PROGRESS!!!
so my parts came in and this is how they were packaged
one of the mounting cups for the rear bags was missing so they made me two brand new ones and sent them out asap.
Old 03-24-2014, 02:02 AM   #79
h2obimmer
Old 03-24-2014, 02:07 AM   #80
h2obimmer
so the wagon has been down for about a month and I've been miserable.
The build originally was put on hold for the following reasons:
I moved to a new state
had to find a new job
make new friends with tools and knowledge to help me
buy parts to replace the old worn out stuff
So i was driving the car as is and then the shock decided to blow out on me.
This prompted me to start working on the build ASAP.
...and then I hit a snag
was removing bolts to pull out old suspension and add in bags and the damn bolt sheared right off
after many many attempts to remove it with my extraction kit and penetrating oil i gave up and decided to take off the entire assembly.
unfortunately, i was unable to remove the axle nut with a breaker bar and my muscles so i had to wait until a friend brought his bad as electric impact wrench and pulled both sides off for me.
bmw, e46, touring, wagon, xit
