Sponsored by BimmerWorld
Old 01-25-2014, 06:32 PM   #1
trentcdrums
My Ride: BMW 323i Sedan
Exclamation What's wrong with my Coilovers?
I recently bought some slightly used ST coilovers from BAV AUTO Recycling and I got everything but the rear spring adjusters. That means I'm bottomed out in the rear and not the front. My ride is worse than when I had my blown suspension...
Will buying rear spring adjusters most-likely stop this or should i refund..
My ride is very stiff my spare tire basically jumps over decent bumps.. ridiculous....
Old 01-25-2014, 06:33 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
Get them to give you adjusters. Why did you install an incomplete suspension system?
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 01-25-2014, 07:02 PM   #3
JapanRot325ci
My Ride: 04 E46
go back and ask them for the spring adjuster like previous post stated. if they don't give you it then i'd refund and buy brand new coilovers for less trouble.
as for stiffness, you can change the damper, i believe there's a knob on top of the strut that can reduce the dampers.
JapanRot325ci is offline   Reply With Quote
Old 01-25-2014, 07:14 PM   #4
trentcdrums
I have asked and they can't because the kit they sold was as is w/o rear adjusters... And Do I need to take the strut off to adjust... and ST is giving an estimate of $140 for a set and Raceland is offering $70 for a set, theres a 1mm difference in spring diameter.
Old 01-25-2014, 07:30 PM   #5
trentcdrums
blank
Old 01-25-2014, 09:59 PM   #6
WDE46
Get the proper size. 1mm is a lot when you are talking about forces over 1000 lbs.
Old 01-25-2014, 10:08 PM   #7
trentcdrums
I'm shady with spending $140 or more for something I'm not guaranteed to know will fix this..
Old 01-25-2014, 10:13 PM   #8
WDE46
Why wouldn't it fix this?
Old 01-25-2014, 10:30 PM   #9
trentcdrums
So you think that it will help my ride because I won't be bottomed out correct?
Old 01-25-2014, 10:37 PM   #10
WDE46
You're missing the threaded mount under the rear spring right? If so, that's like an inch added at minimum height setting.
Old 01-25-2014, 10:47 PM   #11
Alex323Ci
My Ride: M3 & 323Ci (sold)
i forgot to think of the 1mm being important to the forces on it.
because i must have forgot to "submit" earlier my post. i said 1 mm being so small (basically the thickness of a dime) in the difference in diameter of the spring perch i can't see it being a problem. just that to be sure the spring perch is wide enough to hold the spring on and not slide part of it off. also more importantly is that the interior diameter of the spring perch is enough that the spring clears it. too much "slop" and it'll dangle when unsuspended and too close it'll clack on it when it shifts.
i would look at each company's design to see if something could be an issue with the spring seating.
if there is still doubt go with the one that's made for it
with that said what size you need?, TMS sells the H&R ones for $80
http://www.turnermotorsport.com/p-11...1999-2005.aspx
Old 01-25-2014, 10:51 PM   #12
Alex323Ci
i would also be certain that your "used", "as is" suspension isn't blown or damaged. that alone could cause it to perform horribly. also how exactly is that spring being held in place now, from the stock rubber pads prong? does it really fit snug or does it move around, that could be your problem too. lastly if your rear suspension is dumped past it's limits and the front is higher, it's going to react poorly front compared to rear.
Old 01-25-2014, 11:30 PM   #13
trentcdrums
It's deff in there snug. The diameter size on the current ST coil spring in the rear is 61mm
Old 01-25-2014, 11:50 PM   #14
joeysm3
My Ride: ///M3 02
I have ST coilovers my ride feels great. Get the piece. Who told you it would work without it? There is obviously a reason why they come with the kit when you purchase it right?
joeysm3 is offline   Reply With Quote
Old 01-26-2014, 12:00 AM   #15
trentcdrums
I was in desperate need for suspension and bav auto had this kit for $500 shipped and I didn't think I could find a deal with a 6 month warranty like that. The set came from a dinan so I figure they were well taken care of and they deff look like it
Old 01-26-2014, 12:06 AM   #16
joeysm3
My Ride: ///M3 02
Get the piece. Then you dont have to worry about anything. Thats the piece that actually adjusts the spring by the way. Take picture of what the spring is sitting on from the top please.
Old 01-26-2014, 12:17 AM   #17
trentcdrums
It's the rubber perch.
Old 01-26-2014, 01:17 AM   #18
WDE46
Old 01-26-2014, 02:02 AM   #19
Sedan Hussein
My Ride: e46
If they're the type that sit on the bottom of the spring perch, I have a set that I bought for my pss9 kit but didn't need. If they'll work, I'll let them go cheap.
Sedan Hussein is offline   Reply With Quote
Old 01-26-2014, 04:36 AM   #20
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
Whoa whoa whoa WHAT? You paid $500 for a used, incomplete kit when they're only $300 new? You can't possibly be serious...
Cavi Mike is offline   Reply With Quote
