Old 01-25-2014, 07:50 PM   #1
merkme19
My Ride: 2003 bmw 325xi
Headlight buld out?
I have my left headlight xenon bulb that keeps going out. Then randomly ill turn on my car and it will be on (with no discoloration). What are the ways that I can troubleshoot the bulb to see if I can fix it before buying an expensive bulb? Thanks
merkme19 is offline   Reply With Quote
Old 01-25-2014, 08:34 PM   #2
Avetiso
My Ride: 2003 ZHP 6MT
Swap bulbs between headlights. If the problem follows the bulb, that's the problem. If nothing changes, try swapping ballasts. If the problem follows, that's the problem. If neither of these helps, change that ignitor, it's most likely the culprit.
Avetiso is offline   Reply With Quote
Old 01-25-2014, 08:52 PM   #3
WDE46
My Ride: 2004 330Ci OBM
If you do find that you need a bulb, don't go to the dealer. Also replace both at the same time. I'm running Phillips 85122 right now from Amazon. $45 each. $100+ each at the dealer.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 01-26-2014, 01:54 AM   #4
socko
Mine was a short in the ground wire on the driver side xenon headlamp. Local mechanic found it, taped and grounded it and has been fine for about 3 years!!!
socko is offline   Reply With Quote
Old 01-26-2014, 03:21 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
This. Proper way to diagnose the issue. Let us know what you find
Old 01-26-2014, 07:19 AM   #6
merkme19
Thank you everyone ill do some troubleshooting today and get back if I find anything out.
Sent from my SAMSUNG-SGH-I777 using BimmerApp mobile app
