Sponsored by The Tire Rack
Old 01-28-2014, 11:21 PM   #1
AquilaBMW
My Ride: 325i Convertible
Wheel and Tire Sizing on E46 Vert
Hi There -
I am searching around trying to figure out wheel fitment for my car. I desperately want to replace the aftermarket wheels on the car.
I was able to acquire a set of 18" Beyern Mesh Wheels: http://www.beyernwheels.com/BMW_whee...n_typemesh.php
They were on a 128i which shares bore size and off set with the E46. These particular wheels are:
FRONT - 18 x 8.5 / ET 40 / 5 x 120 Bolt Pttrn / 72mm Hub
REAR - 18 x 9.5 / ET 45 / 5 x 120 Bolt Pttrn / 72mm Hub
I plan on reusing the 225 / 45 tires from the current rears on the front, but I am stumped on what to get on the rears. I read that 255 / 35 or so is the way to go, but there are potential under-steer issues with this kind of set up. I am also wondering if a 275 / 35 tire would work on the rears?
Any input would be appreciated.
Thanks!
AquilaBMW is offline   Reply With Quote
Old 01-29-2014, 07:49 AM   #2
MacFady
My Ride: 330i ZHP
All of what you say above has been done. I wouldn't worry about under steer. 255/35 is standard size for the rear on ZHP's for example. 265 is fine too BTW. This is all over the forum, search, I just checked the thread to see if it was for real.
MacFady is offline   Reply With Quote
Old 01-29-2014, 09:03 AM   #3
AquilaBMW
I've been checking, maybe using the wrong search parameters. I'll try again. Thanks for responding. I still have the question about the 275 in the rear though. I was just wondering as this would save me having to buy two new tires as I just happen to have these.
Old 01-29-2014, 12:57 PM   #4
MacFady
My Ride: 330i ZHP
I'm actually not sure about 275, 265 fine. You on stock suspension? 275 may require some fender work but you are ET45 so that helps.
Old 01-29-2014, 01:04 PM   #5
bee-em-dougle-u
My Ride: 2002 BMW 325i
Yes, it will understeer strongly at the limit, but it's really a non-issue if it's a street car that's driven moderately hard (i.e., never really getting close to the limit). If you're concerned about limit behavior/track driving, go with a square setup. Also, aftermarket adjustable anti-roll bars will help...if you go with the Turner/H&R bars and set the rear bar full stiff, it'll reduce the push somewhat.
2002 BMW 325i sedan
Manual gearbox, but of course!
Tasteful mods
128K miles and counting
bee-em-dougle-u is offline   Reply With Quote
Old 01-29-2014, 01:12 PM   #6
tcphoto
My Ride: E92 335 MT Coupe
I recently installed a set of Style 197's on my 325 convertible with 235/40/18 up front and 255/35/18 on the rear. I would seriously doubt that you could fit 275/35 on the rear but offset in critical. Why push it to the limit? I am very happy with my stance and it handles well.
tcphoto is offline   Reply With Quote
Old 01-29-2014, 05:53 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Thread moved to the correct section. Learn to read the forum rule please.
Old 01-29-2014, 05:59 PM   #8
AquilaBMW
If i could fit them, it would save me money as I wouldn't need to buy new tires. I have a pair of fairly new Potenzas in the garage I was hoping to use. I will try it out - I check a fitment guide and it is pretty close.
Thanks! You are completely right. This is NOT going to be tracked or driven to the ragged edge. It is a DD, that will spend a fair amount of time sulking in the garage or doing freeway trips with one - maybe two people in it.
From what I can see, the off set here would be to my disadvantage with these wheels and a 275 rear. But... for shits and giggles, i am going to mount one up and see how it fits.
Gotcha! Thanks!
