Old 01-29-2014, 11:39 PM   #1
EmDeeAr
My Ride: 330i ZHP
What kind of lights do I have?
Car: 2004 330i ZHP
I've heard the terms halogen, HID, xenon, bi-xenon, HID, ZKW, and "adaptive" thrown around when referencing E46 headlights. I'm confused between all of these, and I'm trying to figure out which ones my car is outfitted with.
My lights have projectors, and the light output is a white, bluish color. If the lights are set to turn on when the car starts, the projectors seem to tilt upward or something, seemingly to level out.
The chrome (I think it's chrome...) projector bowls of both the left and right headlights are burnt out. Apparently, this is a pretty common problem, the best remedy of which (I think) is to replace the headlight units entirely (retrofits can be done, but I am set on new lights for the whole package).
There are a ton of different headlight part numbers, so I'm pretty lost as to which ones I need.
RealOEM: http://www.realoem.com/bmw/showparts...29&hg=63&fg=05
Please help meh! Thanks --
EmDeeAr is offline   Reply With Quote
Old 01-30-2014, 12:17 AM   #2
cityjohn
My Ride: 2001 M3
E46 basically had halogen or xenon/HID. In 2001 (as you can see via realoem), there was a switchover in the xenon cars to bi-xenon.
- Halogen is a basic halogen bulb that you can see when you look into the light assembly.
- Xenon has a projector lens. Inner bulbs are halogen and used for high beam
-Bi-xenon uses the outer/xenon bulb for both low and high beam; a mechanical hinged cover creates both beams.
...so it sounds like your car has the bi-xenons
cityjohn is offline   Reply With Quote
Old 01-30-2014, 12:27 AM   #3
EmDeeAr
My Ride: 330i ZHP
Great response, thanks. Turns out one of the diagrams I provided is for pre-face lift cars, so that's cleared up now. (Original post has been edited.)
So, now I just need to figure out which part numbers I need from the bi-xenons listed for the facelift lights.
The options are:
-AL
-AL/ TITAN
-ZKW
^^What does all this mean?
Additionally, since the bi-xenons are pretty pricey, could I just buy the halogens? Plug and play? Will the auto-light function and the LCM be compatible?
Old 01-30-2014, 12:31 AM   #4
farmdog
My Ride: Food Truck
Read here...
http://www.theretrofitsource.com/
farmdog is offline   Reply With Quote
Old 01-30-2014, 12:38 AM   #5
CJin2552
My Ride: 2001 BMW 325Ci
The options are:
-AL
-AL/ TITAN
-ZKW
The TITAN means Titanium, I think that means that you have a Titanium colored headlight insert.
Like this, but silver, not carbon.
You can put facelift halogens into your car, but some wires will not be connected. The "Auto-Level" will not function on halogen lights, and the overall light quality will be diminished. I'd personally recommend a retrofit, that's what I did and I have Quad Xenons. The OEM parts are going to be extremely expensive, last I checked they were ~$1,250 for each set (~$2,500). Naturally, for maybe ~$600 a quad retrofit was the way to go.
Hopefully this helps clears some stuff up, if not I can try to describe what you're not understanding. If you have other questions, maybe I could get you some answers.
CJin2552 is offline   Reply With Quote
Old 01-30-2014, 01:22 AM   #6
EmDeeAr
My Ride: 330i ZHP
Thanks for all the info.
I'm cool with "downgrading" to halogens. Currently, my light output is crap, so anything is better. I'd rather buy new halogens with confidence than try to find a used/bargain set of xenons, pay the exorbitant price for new xenons, or go through the retrofit process. On my car, the headlight assemblies themselves are beat up (broken clips and mounting points, crummy lenses, etc.)..... It all just needs to be replaced. This is just my preference...
I don't even understand the point of "auto leveling." Shouldn't the lights be aligned straight horizontally... always?
If I go with new halogens, will the auto-light feature still work? That is, will the lights still automatically turn on when it's dark enough if the switch is set to the "auto" position (the knob turned left one notch from the neutral 0 position)?
I want to confirm: If I got brand new halogens, would the LCM (light control module) need to be reprogrammed?
Old 01-30-2014, 01:56 AM   #7
cityjohn
My Ride: 2001 M3
I think stricter euro regulations may have something to do with it. Anyway, HID systems are brighter and have a distinct cutoff line to keep the light out of oncoming traffic. Maintaining this line is critical, so the xenon systems use level sensors in the suspension to ensure the aim is correct.
The down-up cycle you hear when you switch on your lights is a self-test and a means of keeping the motors from freezing up.
Old 01-30-2014, 09:38 AM   #8
EmDeeAr
My Ride: 330i ZHP
Oh, see that's interesting. So that leveling feature is built into the headlight unit itself, not the programming of the car?
Old 01-30-2014, 09:48 AM   #9
WDE46
My Ride: '13 128i, '04 330Ci
Car: 2004 330i ZHP
The burned bowls are only a problem on the ZKW bixenon headlights.
I WOULD NOT go back to halogens. You will not be happy with them.
Are you good with a dremel?
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 01-30-2014, 10:04 AM   #10
EmDeeAr
My Ride: 330i ZHP
Hm, yeah, plus halogens won't match the VIN... it's kind of silly to go backwards.
Why are the burnt bowls only a problem with ZKWs? What does ZKW signify?
Old 01-30-2014, 10:13 AM   #11
WDE46
You do need to figure out what headlights you have. What's the last 7 digits of your VIN (serial number)?
Most cars don't have adaptive, so I think these part numbers will do it for you:
ZKW:
Left 63127165833
Right 63127165834
AL (Bosch):
Left 63127165779
Right 63127165780
I wouldn't buy used ZKW, b/c they'll likely be burned out too. Try to find some AL on eBay. Actually, I just checked and they're more expensive than I remember for used. I'd say retrofit something. All you have to do is buy a projector that can fit in there and secure it. You can keep the stock ballast and all that.
Here's a premade solution for you (that's how big of a problem the ZKW lights are):
It won't let me post a youtube link normally so copy paste this:
Old 01-30-2014, 10:18 AM   #12
WDE46
What the **** is going on in my posts. Quote my post and see how stupid this forum is being right now. Won't even show everything.
Old 01-30-2014, 10:20 AM   #13
dknightd
My Ride: 2002 330 cic
I hope I don't have zkw. Would like to know how to tell difference as well. Hope I did not end up with the crappy ones! Second to good windshield wipers, lights are very important to me! I like to see where I am going.
dknightd is offline   Reply With Quote
Old 01-30-2014, 10:24 AM   #14
WDE46
You can just look to see if they're burned out. Check out that video I posted. It's obvious when they're burned.
Figured out the link thing. The forums don't like the https prefix.
Old 01-30-2014, 10:33 AM   #15
EmDeeAr
My Ride: 330i ZHP
Figured it out:
-ZKW is a brand, AL is a brand. AL is also known as Bosch.
-The ZKW brand is simply of inferior quality in terms of the bowls, which is why they burn out.
I still need to decide if I need the AL or AL/TITAN, though.
Any opinion on this?
Also, I found bi-xenons for $800 per side brand new. That's at least reasonable compared to the original $1200ish.
http://www.thebmwpartstore.com/oempa...127165791.html
Old 01-30-2014, 11:22 AM   #16
dknightd
Then align them right
http://www.danielsternlighting.com/tech/aim/aim.html
Old 01-30-2014, 11:24 AM   #17
My Ride: Lexus
Auto leveling compensates for load change whether its passengers or brake/acceleration-induced load change. Actual pointing of the headlights must be maintained manually. (like if you lower your car or change a headlight or something)
As for your lights, $800 a side is good. See if you can find used Bosch units though.
Old 01-30-2014, 05:51 PM   #18
sunsetcoast
My Ride: '99 323i & '00 323iT
^This. And if you want to go with used, you should be able to find them for ~$500/side.
sunsetcoast is offline   Reply With Quote
Old 01-30-2014, 10:33 PM   #19
DOT.
My Ride: '04 ZHP Sedan
All ZHP sedans unfortunately came with ZKWs from the factory... The most cost effective solution is to do a EvoX-R RetroQuick solution from TRS.
Mine:
http://forum.e46fanatics.com/showpos...1&postcount=75
Another forum member:
http://forum.e46fanatics.com/showthread.php?t=990931
The kit:
http://www.theretrofitsource.com/com...ghts-only.html
DOT. is offline   Reply With Quote
Old 01-30-2014, 11:11 PM   #20
WDE46
I have those projectors in my car now. Extremely bright and clear. Crazy cutoff. It turns speed limit signs purple. I like to think its due to color shift from the Doppler effect in the light waves. I'm approaching light speed.
