E46 Convertible
Old 01-30-2014, 12:46 PM   #1
YYCBMW
My Ride: 2003 M3 Convertible
Hardtop Installation Kit Question
I've been searching for a couple days and just want to clarify something. Does the hardtop installation kit ONLY provide power to the hardtop or does it also provide the mounting hardware? I found one thread that said it only supplies power. Need to know because driving 4 hours to pick up a hardtop and the last thing I need is for it to not clamp down. Dealership says it should work without any kit but I'm reading otherwise in the forums.
Thanks y'all!
YYCBMW is offline   Reply With Quote
Old 01-30-2014, 01:00 PM   #2
taylor192
My Ride: 2003.5 M3
Thanks y'all!
The kit is both mounting and power.
Most Canadian verts have the kit from the factory. Remove the tab where the hard top mounts and check if your car has it.
Old 01-30-2014, 01:18 PM   #3
YYCBMW
My car is an import from California.
Old 01-30-2014, 03:12 PM   #4
Poncho@home
My Ride: MY04 330Cic ZSP
ditto, both power and mounting for rear part of roof. In theory you could drop it on without the kit and lock only the front part to the windshield frame, but I wouldn't drive like that, it might be too much stress on the front mount points.
Poncho@home is offline   Reply With Quote
Old 01-30-2014, 03:13 PM   #5
Poncho@home
you should still check if you have the kit installed, PO might have had it done at dealer when purchased new
Old 02-11-2014, 11:20 AM   #6
YYCBMW
I ended up needing the kit. Thanks everyone.
