Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Middle East
Middle East
Old 01-30-2014, 05:45 PM   #1
tomthomb
My Ride: BWM325i '03 Automati
E46 takes long to warm up
my E46 is BMW 325I 2003, takes about 25 min. to get warmed up !! is that normal ?!! and if not, what it could be ?
tomthomb is online now   Reply With Quote
Old 01-30-2014, 05:52 PM   #2
taveet330i
My Ride: Jet Black 2002 330i
Warmed up to what temp? If its to the middleof the gauge without driving then yeah thats normal. Maybe some more details?
[bimmerapp]
_______________
Dedication
2002 Jet Black 330i|ZPP|Hellbeige interior|Carbon Fiber Interior Trim|Alzor 703 CSL Reps|Custom Flowmaster Catback Exhaust|LED Halo Rings|Black ECSTuning Kidney Grilles|Eonon D5150|
taveet330i is offline   Reply With Quote
Old 01-30-2014, 05:58 PM   #3
tomthomb
Yes till the middle, I have to, because if I moved before warming up well once I accelerate it stop totally.
I was have Toyota and mitsubishi but never took that much.
Even a friend was owning BMWx5 wondering
Old 01-30-2014, 06:08 PM   #4
Marshmallow
My Ride: Ehhh...
Search for the hidden obc menu on here. Figure out your coolant temp. Should be in the 90's. Also buy a code reader like pa soft. Your thermostat is likely bad.
Marshmallow is offline   Reply With Quote
Old 01-30-2014, 06:44 PM   #5
taveet330i
Yeah thermostat is probably bad. Do you get a coolant light? Does your heater work intermittently?
[bimmerapp]
_______________
Dedication
Old 01-30-2014, 07:38 PM   #6
Marshmallow
My Ride: Ehhh...
With a stuck open thermostat, heater will work fine but it will take a while to warm up and the coolant light will not come on unless something else is bad. (With the car being as old as it is, there is a real possibility that the rest of the cooling system is bad anyway.)
Old 01-30-2014, 07:48 PM   #7
taveet330i
True, but when my thermostat was jammed open, my heater worked at a sub par level
[bimmerapp]
_______________
Dedication
Old 01-30-2014, 08:00 PM   #8
Marshmallow
My Ride: Ehhh...
That makes sense as well.
Old 01-31-2014, 02:13 AM   #9
tomthomb
Well I will do, I don't know as much s u but u just changed the radiator, not sure ic this info. Is important or not but I found its better to say.
Thank u so much..if it solved I will come and tell
Old 01-31-2014, 02:25 AM   #10
Marshmallow
My Ride: Ehhh...
For what reason did you change your radiator? It's a good thing but I ask because I'm wondering if you had other issues. The entire cooling system should actually be replaced. Considering that you need a new thermostat, it may be a good time to do everything.
Old 01-31-2014, 02:28 AM   #11
tomthomb
I do got heating issue before and cost me to change upper chamber of the engine. .there was leaking in the radiator so I changed it.
What else u advice me to do?
Old 01-31-2014, 02:47 AM   #12
Marshmallow
My Ride: Ehhh...
Here you go. It also has links within for thee maintenance advice.
http://forum.e46fanatics.com/showthread.php?t=914109
Old 01-31-2014, 02:51 AM   #13
tomthomb
So changing the whole heating system will help? Or just a guess
Old 01-31-2014, 04:06 AM   #14
Marshmallow
My Ride: Ehhh...
It's actually called the cooling system. And the main thing that will help you is thermostat replacement but the entire system is likely at the end of its lifespan and so if you can afford it, go for a full replacement to ensure that don't have problems anytime soon.
