Old 02-03-2014, 06:40 PM   #1
jcwilcox@cox.net
My Ride: 2002 M3 Cabrio
ZIZA LED Interior light kit from ECS Tuning
Hi Fanatics,
I have a '02 M3 Cabrio and recently replaced the interior lights with a Ziza LED kit from ECS. All works well except the dome light which will not come on and prevents the rest of the interior lights coming on too. I've switched out LED bulbs but it doesn't help. I've had to put the incandescent bulb back in the dome light and now the system, including the other LEDs works fine. I've tried fiddling with the bulb holders and their fitting into the dome/reading light carrier but with no effect. Any ideas on what may be going on?
jcwilcox@cox.net is offline   Reply With Quote
Old 11-02-2014, 04:55 PM   #2
shackleton1
My Ride: 05 330ci m convert
You have one bulb reversed
shackleton1 is offline   Reply With Quote
Old 11-03-2014, 12:29 PM   #3
heavyweight
My Ride: 2002 325i
im having a similar issue. my led dome light seems to work sporadically, or every other time i start the car.
heavyweight is offline   Reply With Quote
Old 11-03-2014, 12:32 PM   #4
heavyweight
My Ride: 2002 325i
did your kit come with a resistor?
Old 01-10-2015, 07:22 PM   #5
bartman22
My Ride: 2001 LSB M3 Vert
I had the same issue on my 2001 M3 convertible. Same kit, no resistor included. I installed the foot-well and glove box LED's first, all worked great. I then installed the map lights and center dome light. At that point, the map lights continued to work, but the dome light and footwell LED's no longer work.
Mods: Brakes, suspension, working on speed mods...
bartman22 is offline   Reply With Quote
