Sponsored by BimmerWorld
Old 02-05-2014, 11:23 PM   #1
Cees
My Ride: 330i
Exclamation [Suspension] Does this even look right? Koni Str.t + Eibach Sportlines
Koni Str.t + Eibach Sportlines combo
Maybe it's just me but this doesn't look like it fits/lines up correctly... Am I missing something? or does the rubber insulator (pictured with yellow arrow) provide the stopper needed?
I know I should have gone with different struts but I got a good deal for these and have had them sitting for a while.
*In the pictures below you will see the entire sportline set with individual part numbers, and the FRONT L & R Koni struts, as well as the fitment I'm curious about.*
Help appreciated ! Thanks.
ID:	545569   Click image for larger version
ID:	545570   Click image for larger version
ID:	545571   Click image for larger version
ID:	545573   Click image for larger version
ID:	545574   Click image for larger version
ID:	545575   Click image for larger version
Cees is offline   Reply With Quote
Old 02-05-2014, 11:46 PM   #2
ClaytonL
My Ride: 2003 325i
The rubber spring mount needs to be refitted on the new strut. Same thing with the bump stop. Looks like you need a new bump stop anyway.
The spring will not line up with the raised tab on the new strut. I believe it was about 1 inch off on mine. The bottom of the spring is oblong and will fit perfectly. Just move the spring around and you'll see the correct orientation.
ClaytonL is offline   Reply With Quote
Old 02-05-2014, 11:48 PM   #3
ClaytonL
My Ride: 2003 325i
like this-
http://img242.imageshack.us/img242/6233/springseat.jpg
Old 02-06-2014, 04:35 AM   #4
Cees
My Ride: 330i
Originally Posted by ClaytonL View Post
Thank you for your response and reference. I went ahead and finished one side, going to tackle the other in the morning; hopefully all is good with this setup..
Thanks!
e46, eibach, koni, sportlines, suspension
