Sponsored by BimmerWorld
Old 02-06-2014, 01:42 PM   #1
Boondockz
My Ride: 1999 323i
Logic- will lowering you car decrease wear on bushings/ joints?
Recently purchased a 323i 99 5spd. It is lowered on h&r's and the shocks / struts were very done.
The struts were not as bad till I threw on some new rears and all the bounce centered on the front.
Ive got the mounts in the mail (lemfro) I can see loose bearings in my old ones , and out of need and budget had to do Monroe's in the front too at least its something new, even if they only go 20k fronts were 111$ a pop and rear were 34$ each lol
I was just thinking about the bushings and joints when a car is lowered, they dont move as much as normal. so maybe that increases the life span of CA bushings and ball joints ect?
Maybe even the shocks?
Boondockz is offline   Reply With Quote
Old 02-06-2014, 01:44 PM   #2
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
No. Everything either wears the same or sometimes faster due to a harsher ride
Old 02-06-2014, 02:04 PM   #3
Boondockz
My Ride: 1999 323i
That was the other thing I was thinking. Thanks for the response.
Old 02-06-2014, 02:11 PM   #4
Sedan Hussein
My Ride: e46
I'd say it wears quicker as well
Sedan Hussein is offline   Reply With Quote
Old 02-06-2014, 11:14 PM   #5
Boondockz
My Ride: 1999 323i
Threw the front struts in today with lemfro mounts. One of the strut bolts was frozen and I had to reinstall it to break the bolt loose
Upon removal of driver side strut , i found out i need new control arms, that outer ball joint is thrashed bad causing sometimes a clunk and slight 50's shimmy.
Putting my jackstands to good use these days...
