Sponsored by BimmerWorld
Old 02-06-2014, 03:39 PM   #1
aern2005
My Ride: 2003 325i
325i Rough breaking at high speeds
My 03 325i shakes when I am slowing down at high speeds. Should i replace front calipers? and rotors? any suggestions?
aern2005 is offline   Reply With Quote
Old 02-06-2014, 03:56 PM   #2
Riverbmr3
My Ride: MB E350 & BMW 325i
check your rotors and pads, check your control arms and bushing
Riverbmr3 is offline   Reply With Quote
Old 02-07-2014, 02:46 AM   #3
Cowspoo
My Ride: 328Ci
Front control arm bushing.
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 02-08-2014, 03:42 PM   #4
aern2005
My Ride: 2003 325i
I replaced the bushings about 2 years ago...thinking of doing a complete suspension overhaul...any suggestions? Don't wanna break the bank either....
I may also replace the front calipers, pads and rotors while I'm at it....
Old 02-20-2014, 12:42 AM   #5
always-there
My Ride: 2002 BMW 330I
You have to get under the car and inspect possible worn parts to dictate what you have to replace. Diagnose it, you can do it.
Old 02-20-2014, 10:22 AM   #6
aern2005
My Ride: 2003 325i
Just bought new springs and shocks for rear so will inspect the front when I'm done...hopefully can see what's wrong this weekend
Old 02-20-2014, 10:37 AM   #7
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
When was the last time you replaced the front struts. Granted it will probably be your rotors or something else. If all else fails to correct the problem, then I would suspect the struts.
HacksawMark is offline   Reply With Quote
Old 02-20-2014, 10:39 AM   #8
aern2005
My Ride: 2003 325i
Struts, bushings, and links about 2-3yrs ago
