Sponsored by BimmerWorld
Old 02-06-2014, 05:08 PM   #1
S2000
My Ride: E86Z4M, E60M5, M3
E46 M3 std vs. Comp package Brakes
Looking to buy used E46 M3.
I am aware that the Comp package has bigger front rotors.
Are there also differences :
- Front Brake Calipers
- Rear Brake Calipers
- Rear Brake rotors
- Brake booster
I want to know whether one can simply replace the front rotors on std (non-comp) then the std (non-comp) brakes be just as good as comp package.
S2000 is offline   Reply With Quote
Old 02-07-2014, 02:42 PM   #2
Tangent_
My Ride: '01 330i, '11 Z435i
Looking at RealOem, there's definitely more to change. On the front the caliper itself seems to be the same, but the carrier it bolts to is different. (To provide the clearance for the larger rotor) The pads are also different. On the rear, the caliper, carrier, and pads are different. The master cylinder appears to be the same. The rotors are obviously different front and rear.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 02-20-2014, 01:43 PM   #3
Alex323Ci
My Ride: M3 & 323Ci (sold)
well as you know the rotors are different design, front is also larger diameter.
as for the calipers and carriers; they are all different because they are powder coated black. Physical differences are the front carriers are larger and the rear caliper has a larger piston. Pads are same size as stock, but different material.
To buy least amount of parts to switch over, you could get front carriers and rotors. rear caliper will work but the larger piston one would be ideal for bias. master cylinder is the same and untouched.
