Old 02-07-2014, 12:44 PM   #1
Stryker336
My Ride: 2003 330xi
Paint scratches from a shovel
So the other day my car was completely covered in frozen snow. I was late for work and got a little too aggressive with the snow shovel and just noticed how bad I messed up. The roof has some pretty bad scratches and I don't even know where to begin to get this looking half decent. Would the topaz blue BMW paint touch up w/ clear coat do anything to make this better? Any suggestions would be greatly appreciated but I'm not looking for perfection($$$).
Stryker336 is offline   Reply With Quote
Old 02-07-2014, 02:42 PM   #2
justinco
My Ride: 2005 330i ZHP
You definitely want to get some touch paint on it. Clean it up good and let it dry completely, you can then start touching up with the touch up paint. I would do a few layers of touch up paint and let it dry thoroughly.
Once it is (completely) dry you can try wet sanding and then polishing, but that might be beyond the scope of what you are looking at doing. You can make the process as simple or difficult as you want, depending on the results you are looking for
2011 Lexus IS-F | 2005 BMW 330i ZHP (sold) | 1994 BMW 325is autox/track build
justinco is offline   Reply With Quote
Old 02-07-2014, 09:37 PM   #3
FrodoTBaggin
My Ride: 2004 325i
Jesus dude.
FrodoTBaggin is offline   Reply With Quote
Old 02-07-2014, 10:03 PM   #4
wildirish317
My Ride: 2004 325Ci vert
Half decent? Get it sprayed. $500 education about how not to use a snow shovel.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 02-07-2014, 10:05 PM   #5
BlazingWildBill
My Ride: Ferg 328Ci
It will never look normal unless you have it sprayed by a professional.
Post Count:666Sig thanks to Big Rick
BlazingWildBill is offline   Reply With Quote
Old 02-08-2014, 08:01 PM   #6
scrace
My Ride: 03.5 M3
Repaint and after have your whole car polished. It's completely swirled. You'll thank me when you see the results of removing 10+ years off swirls and oxidation.
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 02-08-2014, 11:53 PM   #7
djantlive
My Ride: E46 M3
Dr chip may get it to 90%. But it will take some skills and 2 hrs.
djantlive is offline   Reply With Quote
Old 02-09-2014, 11:49 AM   #8
jclip
Location: Founder of the uber-rare body color roof club
My Ride: 06 m3, 01 325
This appears to be down to the metal. Please do not try to simply touch this up and expect it to not look like sh!t.
jclip is offline   Reply With Quote
Old 02-09-2014, 11:55 AM   #9
Foxtrot_Uniform
My Ride: 325Xi
Sell the BMW and buy a Chevy if you are going to take a snow shovel to it. Chevy's have anti snow shovel additives in their paint.
Foxtrot_Uniform is offline   Reply With Quote
Old 02-09-2014, 10:12 PM   #10
SilvaBimma
My Ride: 330Xi
get bondo and start working as much as you can to repair the damage. add paint, wetsand off. won't be perfect by any means due to the damage. Also invest in a foam shovel for paint.
SilvaBimma is offline   Reply With Quote
Old 02-17-2014, 07:47 AM   #11
jersmith
My Ride: bmw x5
Hello Everybody !!
jersmith is offline   Reply With Quote
Old 02-17-2014, 08:12 AM   #12
AudiEtr
My Ride: 330i
Bondo, paint, then wet sand??? What help does this provide OP?
Originally Posted by jersmith View Post
I'm Jerry from LA been fan of cars for a long time so here i am showing interest in this forum and glad to be here
The way forums work is you read a question/comment posted, then you reply/comment on that post.
Intro post go in the "intro"section.
OP: you can use touch up paint with clear added to help prevent rust right away but it's not going to look great . As others have stated, get it resprayed by a pro. The roof will eventually start peeling if you don't.
AudiEtr is offline   Reply With Quote
