Old 02-11-2014, 09:03 PM   #1
csenf205
Shakes when idle
I have 2003 325i. Just recently this car has started shaking when in idle and occasionally kills the engine. It also has a much harder time accelerating. Any idea on what's wrong with it and how to fix it?
csenf205 is offline   Reply With Quote
Old 02-11-2014, 09:37 PM   #2
Brevik
My Ride: Tiag M3
I put the answer in your other thread
Brevik is offline   Reply With Quote
Old 02-15-2014, 08:52 PM   #3
Boondockz
My Ride: 1999 323i
Shot in the dark here maybe the MAF or fuel filter. Or maybe a big ass vacuum leak. Or maybe injector / spark plug / coils.
Boondockz is offline   Reply With Quote
Old 02-15-2014, 08:54 PM   #4
Boondockz
My Ride: 1999 323i
Fuel pump maybe....shakes is little or no info. Try searching.
Old 02-15-2014, 09:29 PM   #5
aproblem
My Ride: 2001 330Ci
vanos or vacuum leak? i had rough idling until i fixed my vanos
aproblem is offline   Reply With Quote
Old 02-16-2014, 02:00 PM   #6
tsalhani5
A buddy of mine had a similar problem and it was simply due to his spark plugs. Other than that it could be motor mounts.
tsalhani5 is offline   Reply With Quote
Old 02-20-2014, 05:06 AM   #7
gregor1
My Ride: BMW 330 ci
Engine sucking in air at idle - probably a hole in a breather hose - if you get misfire warning from OBD it can be caused by this problem.
gregor1 is offline   Reply With Quote
Old 02-21-2014, 12:48 AM   #8
1`
Banned User
My Ride: 330i
I have this happen mild vibration, never causes issues like cutoff though. Happens while idle and not always. Engine feels a little rough during these times. I was wondering what the issue was. Sometimes the vibration is nonexistent, other times it's a bit rough. Only while idling (in drive while not moving).
Suggestions?
1` is offline   Reply With Quote
Old 02-21-2014, 03:55 PM   #9
csenf205
I put all new coils and plugs in it cleared most of the codes. I think I've narrowed it down to a fuel issue. Pump sounds like its slowing dying on me. I'm going to replace the fuel filter and pump since this is likely something id have to do down the road anyway.
Old 02-21-2014, 04:13 PM   #10
Sedan Hussein
My Ride: e46
Definitely give it a full tune up and go from there. Now that the plugs are done, replace the fuel filter then clean the MAF and ICV.
Sedan Hussein is offline   Reply With Quote
Old 03-07-2014, 09:53 AM   #11
inebriation
My Ride: 2002 330ci
Check for tightness in your sparkplugs and also check for vacuum leaks. Might.even want to get under the car and check the condition of your engine mounts. When mine failed there was a noticeable shudder in the car at idle and all of that was cured by new mounts. Just guessing here and trying to help!
inebriation is offline   Reply With Quote
Old 03-07-2014, 10:10 AM   #12
Xeus
My Ride: 1999 BMW 323i
SES on? any codes?
Xeus is offline   Reply With Quote
Old 03-08-2014, 09:17 PM   #13
headmaster
My Ride: e53/e60
I'm with sedan, check the icv, clean the maf. Also, how old is the disa valve? I've seen these "leak" before they fail, as the plastic gets more brittle and causes similar symptoms. Could also be a bad fuel filter..
headmaster is offline   Reply With Quote
