E46 Xi Forum
Old 02-13-2014, 04:19 PM   #1
Solomax
My Ride: 2003 325xi
2003 325xi rack and pinion replacement!
My rack and pinion is leaking pretty bad on my 325xi, so I was wondering if I can replace it with a rack and pinion from an e46 non-awd.
Solomax is offline   Reply With Quote
Old 02-17-2014, 12:30 PM   #2
330xijonny
My Ride: 2003 330xi
I just purchased a new steering rack for my 330xi. Apparently they are different, but I don't know definitively that you couldn't use one off of a rear wheel drive. Considering the unknown engineering that goes into these components, I wouldn't use the wrong part on any BMW system unless you enjoy doing thing twice
330xijonny is offline   Reply With Quote
Old 02-17-2014, 01:11 PM   #3
SamDoe1
My Ride: 4cyl of fury
They are different. Get one from rack doctor. Are you sure the rack itself is leaking or could it be one of the hoses?
Old 02-17-2014, 01:45 PM   #4
Solomax
My Ride: 2003 325xi
Thanks for the replies! I went the safe route and bought an oem rack because I didn't wanna hurt my baby! How much did you pay for yours Johnny?
Old 02-18-2014, 09:37 AM   #5
SamDoe1
Rack doctor is rebuilt OEM racks...
Old 02-18-2014, 09:47 AM   #6
Solomax
My Ride: 2003 325xi
Yeah but I got one for about $100 less from parts geek. And I'm sure the rack was bad, a BMW tech told me!
Old 02-18-2014, 10:49 AM   #7
SamDoe1
^ That means nothing to me. Unless the BMW tech showed me the leak and I confirmed it myself I'd be suspicious. If a BMW tech told you that you need a new engine would you do it without more research?
Old 02-18-2014, 11:58 AM   #8
330xijonny
My Ride: 2003 330xi
[QUOTE=Solomax;16008546]Thanks for the replies! I went the safe route and bought an oem rack because I didn't wanna hurt my baby! How much did you pay for yours Johnny?
I payed $200... I wouldn't recommend other people go this route, but I found one at a local auto recycler and I wanted to swap it out the weekend I bought the car. Also, I was able to inspect it beforehand, otherwise I wouldn't have considered it... even then, its a gamble and I may be throwing $200 to the wind. I consider it cheap entertainment. Rack doctor really is the way to go and if I have to replace this again that's definitely the route I'm going. A rebuilt rack will set you back a little over $300 on the XI and it includes a lifetime warranty (can't beat that!)
Old 02-23-2014, 04:03 PM   #9
Acts238
My Ride: 325
SoloMax did you ever find a Solution?
I recently Replaced my Rack & Pinion.
I bought mine from Orielly Auto Parts, Rebuilt one for Around $450.00
Acts238 is offline   Reply With Quote
Old 03-13-2014, 10:42 PM   #10
Solomax
My Ride: 2003 325xi
Acts I bought one off eBay for $100 and installed myself, works good as new!
Old 09-18-2015, 09:23 AM   #11
dwat1000
My Ride: 02 BMW 325xi
I'm replacing my rack on a 02 325 xi. I got it loose but can't get the dad gum thing out for the Frame. what do I need to do to get this thing out.
dwat1000 is offline   Reply With Quote
Old 09-18-2015, 07:45 PM   #12
dwat1000
I got the dad gum thing out. Boy what a pain. Had to drop the frame a bit. Loosened the two front bolts and two rear bolts, use jack to lower also had to remove 4 bolts on the sway bar I believe on the very front part of the frame. That gave me the clearance I needed to do the job. Took me about 6 hrs to figure everything out. Know just needs an alignment. I don't know why I got this xi. Everythings more expensive and a little harder with the xi. Anybody need help with there's let me know.
Old 09-20-2015, 08:57 AM   #13
Kubica
My Ride: 2003 325xi
Think about replacing those four subframe bolts. Definitely torque them properly.
Old 09-20-2015, 09:48 AM   #14
dwat1000
You wouldn't happen to know the torque specific on those bolts. Thanks I will look into that. I wonder where's a good place to find some other than BMW.
Old 09-20-2015, 10:03 AM   #15
dwat1000
Got an alignment at firestone yesterday. The guy talked about me so bad. He said who ever did it didn't even try to match the new rods with the old ones, which really wasn't true. I worked like heck to getting it close to the before even counting threads and using chalk. I think he really just wanted a reason to charge me double $129. My response was, YOU GET WHAT YOU PAY FOR. That being said new rack$ 225 ,new tie rods out and inner $80 in, no leaking, handles a bit better, and very we'll aligned now. I'm very pleased. No more immediate issues as of now, except rear rotors and pads bit that's elementary. Keeping my fingers crossed. I in about $3500 on this car and still pleased at this point.
