Old 02-14-2014, 07:23 PM   #1
Twisted Polak
My Ride: 09 Jaguar XF S/C
Bunch of Engine Codes Help please
I do not own the car yet but I would like to purchase it. the car is a 2000 323ci with 160k on it. it currently does not start and I would really like to repair the problem myself. here is a list of the codes that it has..... I have read on one of the forums that the car could just simply be out of gas. please help in anyway that you can. thank you in advance.
P1250
P0300 - Random/Multiple Cylinder Misfire Detected
P0303 - Cylinder 3 Misfire Detected
P0305 - Cylinder 5 Misfire Detected
P0301 - Cylinder 1 Misfire Detected
P0170 - Fuel Trim Malfunction (Bank 1)
P0173 - Fuel Trim Malfunction (Bank 2)
P1523 - "A" Camshaft Position Actuator Signal Low Bank 1
P1188 - Fuel Control (Bank 1 Sensor 1)
P1189 - Fuel Control (Bank 2 Sensor 1)
P1189 - Engine Oil Pressure Switch Circuit
P1470 - Leakage Diagnostic Pump Control Circuit Electrical
Twisted Polak is offline   Reply With Quote
Old 02-21-2014, 05:56 PM   #2
Twisted Polak
bump
Old 02-22-2014, 09:44 PM   #3
lszlszx
My Ride: 1.8T, XC70
Most likely vacuum leaks, CCV, DISA, intake boots.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
