Need help with rattle noise!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-15-2014, 12:39 PM   #1
trivium630
My Ride: 2003 325i
Noise will go away when rpms are above 750, any ideas?
trivium630 is offline   Reply With Quote
Old 02-18-2014, 08:59 AM   #2
juslookin
My Ride: 05 330ci ZHP
Get idle adjusted to above 750
juslookin is offline   Reply With Quote
Old 02-18-2014, 09:38 AM   #3
Sansho
My Ride: 2001 325i
Can you provide any clues to what you're hearing? Have you lifted the hood to see if your can isolate where the rattle might be coming from? Does it only occur at a certain time, like within the first two minutes after starting a cold engine? or ????
Sansho is offline   Reply With Quote
Old 02-18-2014, 10:04 AM   #4
trivium630
My Ride: 2003 325i
It will start after about a minute or two after starting engine, seems to get louder as car warms up, unable to pinpoint where it's coming from
Old 02-23-2014, 11:48 AM   #5
CPA325i
I had this problem before and I had my mechanic check it out while I was getting new winters fitted and found out it was a loose exhaust bracket. They tightened it up no extra charge and had no rattle since. It was a very similar rattle for myself, only around 500-800 rpm. Hopefully it's as easy of a fix for you.
CPA325i is offline   Reply With Quote
Old 02-23-2014, 12:47 PM   #6
trivium630
My Ride: 2003 325i
I was kinda thinking that. Have to get up on lift and check it out, thanks
