Old 02-19-2014, 06:09 PM   #1
jromero
2001 bmw 330i trunk issue
I was replacing my car battery. So I took it out but then I closed the trunk. So now I'm stuck out of my trunk and can't start my car. The key I have does not open up the back. And for some reason jumping the car won't work either. Any advice?
jromero is offline   Reply With Quote
Old 02-19-2014, 07:08 PM   #2
Tangent_
My Ride: '01 330i, '11 Z435i
Turn the key beyond what you normally would in the trunk keyhole; it'll manually open it.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 02-19-2014, 07:31 PM   #3
jromero
The key only goes in about 25% in the trunk keyhole though. Would it still work
Old 02-19-2014, 07:51 PM   #4
Tangent_
That's odd... Is the lock damaged? In any case as long as you can turn the lock at all, just turning it past the "open" point you're used to should get you to the manual actuation point.
Old 02-19-2014, 08:49 PM   #5
jromero
Alright thanks I'll give it a try hopefully it works
Old 02-19-2014, 08:57 PM   #6
travisn
My Ride: Nothing
Sounds like a battery cable is loose.
Can you open the hood? Put jumper cables/another car at the appropriate locations to give your car enough power to open the trunk
travisn is offline   Reply With Quote
Old 02-20-2014, 09:34 AM   #7
jromero
I have already tried using jumper cables for some reason that wont work either. At this point calling the dealer ship seems as the best choice
Old 02-20-2014, 01:02 PM   #8
auto feature
My Ride: E46 318i/E90 320i
So, can't the key manually open the driver's side door?
auto feature is offline   Reply With Quote
Old 02-20-2014, 01:22 PM   #9
jromero
Is there a latch or trunk release inside the trunk of 2001 bmw 330i
Old 02-20-2014, 02:25 PM   #10
slammin_330
My Ride: is no ZHP.
Yes. There is one in case you get locked in the trunk. It's in the lid.
Should be able to power up the car by hooking to the + and - lugs in the engine bay. That's how we change a battery without loosing presets, etc.
Or I've gotten into them by getting under the car (when it was locked up and couldn't get the hood open) and jumped the + on the starter. IIRC that was a flood victim X5 and it didn't have any key holes on the exterior of the car, but same principle applies.
Valet key will not open the trunk, so if you don't have the real diamond key with buttons you need to get one.
1974 Jensen Healey
1988 524Tds/5
1994 550iT/6 (Gristle Hammer)
1995 318Ti Clubsport
2001 Discovery 2, M54B30 swapping
2003 330i/5
slammin_330 is offline   Reply With Quote
