Where to buy perfect fitting single DTM exhaust tips for M3? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 06-07-2002, 11:05 AM   #1
advan24r
Banned
My Ride: 2002 LSB M3 6-spd
Send a message via ICQ to advan24r Send a message via AIM to advan24r
I'm looking to replace my regular stock tips w/DTM ones..where can I get perfect fitting ones that protrudes out as much as some aftermarket exhaust like Eisenhaus, SS,..etc and are bolt ons like the OEM ones..I don't like those cheap BORLA tips where you basically screw it on and the tip protrudes 234534623456 inches out! Thanks!
advan24r is offline   Reply With Quote
Old 06-07-2002, 11:50 AM   #2
Mr.Stream
My Ride: '07 BMW Z4C 3,0SI
Send a message via AIM to Mr.Stream Send a message via MSN to Mr.Stream
I know Remus makes single DTM tips. I found these. The badge is only something that the dealer where I buy things put on so they can sell it as their own.
Stig Johansson
Norway
Hellrot '07 BMW Z4 Coupe 3,0SI
Sparkling Graphite '06 BMW 318i Touring
Mr.Stream is offline   Reply With Quote
Old 06-07-2002, 02:42 PM   #3
Rob Levinson * UUC Motorwerks
UUC Motorwerks, *******
Rob Levinson * UUC Motorwerks's Avatar
My Ride: 7s, M5s, M3s, others
I just held these up for comparison...
http://www.nexternal.com/uuc/?Target...s.asp&RowID=85
This shows our standard 3" tips which we made available as an upgrade for non-M3 E46:
If you remove the riveted-on trim tip, it looks like our tip should fit over the inner pipe:
However, if that does not prove to be the case, the necked-down portion of our tip can be cut off, and the 3" diameter could be tack-welded over the original trim tip:
I think these might just work perfectly!
- Rob
- Rob Levinson * UUC Motorwerks * 678-679-5360 * uucmotorwerks.com
BIG BRAKE KIT HEADQUARTERS!
ALL CURRENT UUC SPECIALS:
-[ CLICK HERE ]
Rob Levinson * UUC Motorwerks is offline   Reply With Quote
Old 06-07-2002, 03:48 PM   #4
advan24r
Banned
So Rob, no modification is needed for the UUC tips? Just undo the old oem ones...and put the new ones on? How much are they? Also, rob..when are you guys coming out w/the illuminated rob knob III? I have the UUC SSK..need a heavier shift knob!
Old 06-07-2002, 03:52 PM   #5
advan24r
Banned
how much is it to weld tips at a shop anyways?
Old 06-07-2002, 05:02 PM   #6
That's what it looks like. I have not drilled out the rivets on the OE exhaust here to check... I only looked because you asked! ;-)
But it looks like that's all that should be required.
How much are they?
$45/pair, you can even click on the link in my previous post to order them.
Almost done, a few more weeks!
- Rob
-[ CLICK HERE ]
Old 06-07-2002, 06:11 PM   #7
advan24r
Banned
Rob, is there anyway you can find out if they fit FOR SURE?
