Sponsored by BAVSOUND
Old 02-20-2014, 12:56 PM   #1
thegenius46m
My Ride: E46 M3, E63 M6
Question Hybrid Audio Technologies Imagine Coupe Front Door Fitment
So I am looking to get these for my front doors and was wondering how they fit in the M3? I know the 6.5" speakers will be fine after some adapters, but my main concern is the tweeters. Does anyone know if they can fit within the stock tweeter location without substantial modifications? I can't seem to find anyone who has done it yet.
http://store.12velectronics.com/imag...l-speaker-set/
2003 E46 M3 TiAg/Cinnamon 6MT
Purchased:11/13 with 58k miles
thegenius46m is offline   Reply With Quote
Old 02-20-2014, 03:22 PM   #2
kgvickers
My Ride: 2003 330i ZHP
There's plenty of space behind the "sail" panel grill to make it work, but those tweets won't fit in the stock tweeter mounts.
Get some plumber's tape (metal "tape" with holes) and hot glue, two sided tape, or whatever else you've got lying around your shop. It shouldn't take too much effort to hold them in place. There's a piece of foam in that area, you'll need to cut the opening in the foam a bit, but it should be fairly easy to make something work.
Just give Hybrid Audio a call, I bet they've fielded this question before.
Are you using the stock HK amp or going aftermarket?
Keith
'03 330i ZHP, Mine
'04 330i, Wifeypoo
'98 328i, Son
kgvickers is offline   Reply With Quote
Old 02-20-2014, 09:40 PM   #3
thegenius46m
Will be going with aftermarket amp once I decide which one I want. Do I need an LOC if using the stock headunit? And I am not planning to run subs.
Old 02-20-2014, 10:00 PM   #4
thegenius46m
I'm thinking I'll buy some HK pillar grilles and mount the tweeters in that location like this guy did. Saw an individual who mounted them there without the grilles, but I'm going for the OEM+ look.
http://forums.bimmerforums.com/forum...udio-treatment
Old 02-21-2014, 09:49 AM   #5
kgvickers
Hmmmm . . . I just recalled something - you don't have tweets in the A-pillar, right? Those HK grills that you see in the sedans are part of the door trim and I don't know if you'll be able to directly swap those into your coupe.
I'd recommend you go with an aftermarket amp with a fully balanced, differential input. I've used a few Alpine amps and they worked just fine without an LOC. I simply spliced RCA plugs on the stock wiring (removed from the stock amp in the trunk) and connected that directly to the Alpine amp. Note the following quote from the forum thread you posted:
"The Blaupunkt VA4100 amplifier was installed using the CD43's balanced differential output. All of the neccessary wires are available in the trunk of the car, so running new cables to the head unit or speakers is not necessary. The passive crossovers included with the Clarus component set were also mounted in the trunk and connected to the factory speaker wiring."
Somewhere on one of these forums I saw a list of "balanced-input" amps that are compatible with the stock head unit. If I can find it I'll edit this post with the link.
You can read more discussion here: http://forums.bimmerforums.com/forum...tial-HU-output
Keith
'03 330i ZHP, Mine
'04 330i, Wifeypoo
'98 328i, Son
Old 02-23-2014, 11:05 AM   #6
StereoInstaller1
My Ride: 4 door demo booth
Yes, please do go read that post on BF.c: BMW does NOT use balanced differential.
Please, for the sake of future enthusiasts and car audio upgrade hopefuls around the world, please stop repeating that nonsense.
Go read this: http://en.wikipedia.org/wiki/Balanced_audio
Balanced requires 3 wires, BMW has 2. End of debate.
Luke
StereoInstaller1 is offline   Reply With Quote
Old 02-24-2014, 10:05 AM   #7
BananaHammock
My Ride: 2004 Phoenix Gold M3
http://en.wikipedia.org/wiki/Balanced_line
In telecommunications and professional audio, a balanced line or balanced signal pair is a transmission line consisting of two conductors of the same type, each of which have equal impedances along their lengths and equal impedances to ground and to other circuits.[1] The chief advantage of the balanced line format is good rejection of external noise when fed to a differential amplifier. Common forms of balanced line are twin-lead, used for radio frequency signals and twisted pair, used for lower frequencies. They are to be contrasted to unbalanced lines, such as coaxial cable, which is designed to have its return conductor connected to ground, or circuits whose return conductor actually is ground. Balanced and unbalanced circuits can be interconnected using a transformer called a balun.
http://forum.e46fanatics.com/showthread.php?t=245914
BananaHammock is offline   Reply With Quote
Old 02-27-2014, 02:47 PM   #8
kgvickers
Luke
I think whether "balanced signal" means two wires or three wires is a matter of context. Long microphone runs commonly use three wires. My research (and experience) in general audio like car stereo means two wires.
In the BMW CD53, the "grounds" or "returns" for the speaker outputs are not referenced to chassis, meaning that they are not at the same potential / they are not "tied" to the chassis. Futher, the returns, all four of which are "BROWN with a narrow ORANGE stripe" wires, are not tied to each other internal to the radio despite all being the same color.
So I don't know if that means they are balanced, and/or differential, or both. I would be happy if someone would tell me the proper term for that signal. However, based on BananaHammock's wiki quoted above, I'm inclined to call it a "balanced signal pair".
Just for reference, if you look at any AudioControl product manuals, they mention "balanced" vs "unbalanced" inputs. And those have nothing but RCA (two connector) inputs and outputs.
What I am absolutely 100% certain of: If one chooses the right aftermarket amp, an LOC (Line Out Converter) IS NOT necessary for the CD53! I've tried a commonly recommended LOC and I personally think it actually had a detrimental impact on the SQ. So I avoid them if at all possible.
I've had success simply taking the four channels of output from the head unit, splicing them into RCA plugs, and then putting them directly into the "line-level" inputs of the amp. I've been happy with Alpine amps. They are cheap second-hand on craigslist and readily available. I'm not going to claim they are the best SQ but my ancient, part deaf ears are happy with them.
Keith
'03 330i ZHP, Mine
'04 330i, Wifeypoo
'98 328i, Son
