Sponsored by BimmerWorld
Old 02-22-2014, 05:41 PM   #1
straight_beamin
My Ride: 2000 bmw 323i
Technician telling me Bilstein Sports are not compatible with H&R race springs
So I just received new rear shocks and front struts. (Bilstein Sports to replace my worn Bilstein HD's). I replaced the rears and everything went fine, onto the fronts.... took the strut units out and took them to a local shop to transfer the good H&R race springs from the old ones to the new ones (I dont have a spring compressor and cant be bothered).
Get to the shop and they attempt to put the H&R race springs onto the Bilstein sports, he comes back into the waiting area and says "these springs are not compatible with the sport struts". Im confused here?? not looking for an argument i simply said ok and left. This was canadian tire by the way (basically a walmart style big box garage) yes it was 4pm on a saturday so I had no choice.
I hear of tons of people running these struts on the sports without any issue so just asking for any advice.... he said basically im trying to lower the car two ways and i should just use factory springs because of the perch being higher yada yada
straight_beamin is offline   Reply With Quote
Old 02-22-2014, 07:39 PM   #2
straight_beamin
bumpdy dumpty
Old 02-22-2014, 08:01 PM   #3
lszlszx
My Ride: 1.8T, XC70
I tend to believe that, some combination struts and springs will work but basically if a strut/shock operates at a low part of it's range, it may wear out faster.
In other words, the Bilstein sports are for normal height, or slightly lowered set up and the H&R race springs must be quite big drop.
I had a similar situation with another car and the struts wore out real quick.
The best you can do is contact either Bilstein, or H&R to find out.
Also post in the suspension subforum.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 02-22-2014, 08:12 PM   #4
straight_beamin
http://www.bilsteincanada.com/produc...oducts_id=2370
says in the first few sentences that it is "an excellent match for vehicles with lowering springs or anti-roll bars".
my bad about the wrong section
Old 02-22-2014, 08:15 PM   #5
straight_beamin
it is the bilstein heavy duty shocks that are designed for normal ride height. had them on a slammed car for 80k miles till they were shot. bought these sport shocks because it says its meant for lowering springs
Old 02-22-2014, 08:25 PM   #6
lszlszx
My Ride: 1.8T, XC70
They should work OK then. Why don't you order a spring compressor from Harborfreight. Last time I checked it costed only like $15.
Old 02-22-2014, 08:31 PM   #7
straight_beamin
ya i might just do it myself.... always get nervous around spring compressors after seeing some gone wrong videos on youtube lol. reassuring to see it should work though. if anyone has this setup please chime in!
Old 02-22-2014, 09:26 PM   #8
straight_beamin
been checking around the web, people have this setup on e46... maybe the techs just didnt want to bother 4pm on a saturday?
Old 02-24-2014, 04:44 PM   #9
straight_beamin
installed yesterday no problem by myself. canadian tire is a joke
Old 02-28-2014, 05:10 PM   #10
straight_beamin
Highly reccomend bilstein sport shocks and struts. A bit sportier so bumps are a tad bit harsh but the handling is awesome and love has been restored.
Sent from my GT-S7560M using BimmerApp mobile app
Old 03-06-2014, 01:57 PM   #11
bimcwe
My Ride: 2002 330xi 5 Speed
nice going.
Look at it.
bimcwe is offline   Reply With Quote
Old 03-06-2014, 02:09 PM   #12
tachi1247
My Ride: '04 330i
H&R race springs are probably the second most popular springs to run with bilstein sports (1st being h&r sports). As you've already proven, big box store mechanics are not the best out brightest...
tachi1247 is offline   Reply With Quote
Old 03-06-2014, 07:07 PM   #13
white46
My Ride: e46 323ci
Your very first mistake was taking your car to crappytire. lol
white46 is offline   Reply With Quote
Old 03-06-2014, 08:04 PM   #14
YYCZHP
My Ride: 2005 330ci zhp
Never had an issue with crappy tire, just tell them exactly what you want done and watch them do it. They are all Filipino at the one by my house and do a great job if you give them proper direction.
YYCZHP is offline   Reply With Quote
