Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Southwest
Southwest
AZ NM NV OK TX UT
Old 02-23-2014, 10:39 PM   #1
Sergzam
My Ride: Snow pckg e46 325i
Houston Tx Bmw Programmers
I was wondering if anyone in the area has the software to turn off my day time running lights?
Sergzam is offline   Reply With Quote
Old 02-24-2014, 12:18 AM   #2
mack89
My Ride: '02 TIAG 330i 5spd
All you need is BMW scanner 1.4.0 and PA soft. I have a spare one, it works fine, and I can have it shipped to your home. Let me know if you're interested!
mack89 is offline   Reply With Quote
Old 02-24-2014, 03:33 PM   #3
Sergzam
Pm sent
Old 04-01-2014, 03:45 PM   #4
Sergzam
Here I am bumping once again to see if anyone can or knows a shop that can code two things for me the drl off and the lock windows setting
Don't mind paying just not 225 dollars for two silly things
Old 04-01-2014, 07:27 PM   #5
haurelio
My Ride: 2001 bmw 325i
I have the pa soft for sale. Pm me interested
Contact me if you need to unlock your phone.
Also can code your car
Old 04-01-2014, 07:47 PM   #6
ChuckyVee
My Ride: 2000 323i, '99 328is
Damn! I want my DRLs programmed on!
First Bimmer..."Miss December"...2000 323i, purchased Dec. 2013 w/82K on the clock. PM thus far...pads/rotors, belts/pulleys, complete CS overhaul, FCABs, plugs, autotranny/differential service, fuel pump, filter, and relay. Full front end refresh with LCAs and bushings, struts and mounts, inner/outer tie rods, sway bar endlinks and bushings.
ChuckyVee is offline   Reply With Quote
Old 04-01-2014, 08:02 PM   #7
Swater330i
My Ride: 2003 BMW 330i 5MT
mack89 did one of our cars a while ago with his laptop software. If he isn't too far away I think he's your best option other than buying your own kit
Originally Posted by phenom323ci View Post
I am going to install M3 fender grill on my 323ci.
Originally Posted by futureSubie View Post
IMO, the euro clear corners looks too aftermarket/ricey.
Originally Posted by Davconelectric View Post
This 323 would most likely handle and drive better than a stock e46 m3.
Swater330i is offline   Reply With Quote
Old 06-17-2014, 03:29 PM   #8
wdaveweaver
My Ride: 2004 330i ZHP
I'm in Houston and have PAsoft and I also have SSS and INPA with a new cable on the way. I've done my DRLs and others if you still need help PM me and you can swing by my house and I'll get it done.
wdaveweaver is offline   Reply With Quote
