Old 02-24-2014, 03:29 AM   #1
veli510
My Ride: 2001 BMW 330i
P1500 Code
I have 3 fault codes actually. p0171,0174 and 1500. I did research about the 171 and 174. People says it's a vacuum leak, i will order some stuff to build a smoke machine later, but not sure what the p1500 is. Any ideas? thanks
veli510 is offline   Reply With Quote
Old 02-28-2014, 12:31 PM   #2
darrenswebdesigns
Idle speed control valve is p1500 the others are vacuum leaks check the lower intake boot !
darrenswebdesigns is offline   Reply With Quote
Old 02-28-2014, 03:50 PM   #3
veli510
is idle control valve different from idle speed control valve? if so, where is the idle speed control valve located?
Old 03-03-2014, 05:27 AM   #4
veli510
Thanks for the replies. I reset the code a week ago and hasn't popped up since. I was due for a smog. Went on Saturday. Passed with flying colors. Weird but I'm happy. At least it passed
