Old 02-24-2014, 07:11 PM   #1
325ci_c150
My Ride: 2003 325ci
Help!!!! Clutch pedal rock hard
Help so literally like 5 minutes ago, I was suspecting that my clutch was slipping a little, and I read that while going down the highway throw it into first then rev it with the clutch still in then throw it into first and see if the rim drops. Which now I think was really really dumb once I threw it into first I heard a loud bang and the clutch pedal went rock hard and now I'm stuck on the side of the road. It still goes into all the gears easily sitting here. And on top of that I thought my be I could drive it without the clutch if it was that so I tried to start it by pushing 5 he clutch down the clutch pedal snapped to add insult to injury. So did I blow up my tranny or is it a bad clutch.......
2003 325ci
325ci_c150 is offline   Reply With Quote
Old 02-24-2014, 07:12 PM   #2
325ci_c150
My Ride: 2003 325ci
First then into fifth*
2003 325ci
Old 02-24-2014, 07:43 PM   #3
emgee
My Ride: 3 pedal 2005 325xi
emgee is offline   Reply With Quote
Old 02-27-2014, 04:16 AM   #4
wanganstyle
My Ride: e36 M3 / E30 GTS1
Halp.
I think you should post this on r3vtard as they probably have most experience with shifting to first gear while at freeway speed.
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 02-27-2014, 07:23 PM   #5
Tangent_
My Ride: '01 330i, '11 Z435i
When you can shift it into gears just sitting there, is that with the engine running or off? Throwing it into first at highway speeds is a recipe for grenading your engine... Whoever said to do that was trolling you or really dumb. You can check clutch slip at highway speeds by hitting the clutch, revving up the engine, and then dumping the clutch while hitting the gas all while still in 5th (or 6th) gear. There's no reason whatsoever to go into first at any point of this process...
The clutch pedal being rock hard makes my first suspect a broken clutch. If it was a non-dual mass flywheel I'd think a spring broke out of the clutch disc and jammed between the disc and flywheel or pressure plate. With the dual mass setup like we have stock I dunno what would have broken there. Otherwise maybe trying to jam it into first at way too high of a speed blew up the synchro or damaged a shifter fork and the transmission itself is borked. It feels like it's going into gear, but it's actually jammed into having two gears engaged at once essentially. That wouldn't explain the hard clutch pedal though. Whatever it is, I doubt it's gonna be cheap or easy to fix.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 02-27-2014, 09:26 PM   #6
badfast
My Ride: A car
Pretty much this. You won't be able to tell the extent of damage until the transmission is pulled.
badfast is offline   Reply With Quote
Old 02-27-2014, 10:58 PM   #7
Bavaryan
My Ride: 330i w/out park.
Fifth to first on the highway? Best case blown clutch, second best case blown transmission, third best case blown engine. Worst case you grenaded all three.
You followed some very bad advice and now it is time to pony up some $$$$$ or buy another car.
Good luck, I hope I'm wrong.....
Bavaryan is offline   Reply With Quote
Old 03-05-2014, 05:53 PM   #8
dardarwin01
My Ride: 330ci
Did you really push it into first, at that high speed updates op
dardarwin01 is offline   Reply With Quote
Old 03-11-2014, 08:29 PM   #9
Landlorder
My Ride: 330CI Sport
He would have over revved his engine if he was over 40mph easily - I went from 6th to 2nd at 80mph when I first got my car and bent loads of valves !
Landlorder is offline   Reply With Quote
Old 03-13-2014, 04:58 PM   #10
JDUTHIE
My Ride: 2003 325xi
YOU REALLY HAVE TO "push" IT INTO 1ST AT HIGHWAY SPEEDS AHAHAHA WOW HOLY FAIL THREAD. OP IF IT STILL GOES INTO GEAR, ID CHECK OUT THE FORK, OR SLAVE. BUT WHILE YOUR IN THERE AHAHAH BUY A NEW CLUTCH AND PRAY?
JDUTHIE is offline   Reply With Quote
Old 03-14-2014, 03:01 AM   #11
dardarwin01
My Ride: 330ci
I think that's still unbelievable, it's common sense you downshift 1 gear or 2 at a time with low rpm or three if you really wanna slow down/ stop quicker. 4 or 5 gears is doing to much. If you need advice ask on this thread. If you really need to test your clutch, you need to be at a full stop. be in say seconded and or third gear and rev the engine let go off the clutch and than if your car dies it's a bad clutch. Slippage will occur In high gears.
