Old 02-25-2014, 10:09 AM   #1
Brickhole
My Ride: 325i
Transmission swap ZF>GM
I have a chance to buy a good used transmission out of a car that is the same year as my car. The only difference is that my transmission is a ZF and the replacement one is the GM one. Will this work? Do I need to swap transmission control units too? Are the cooler lines the same? Is the electronic connector the same? I will be able to use two lifts and swap everything over, just haven't looked at them too closely yet cause the donor car isn't easily accessible right now. Looking to swap it out Friday. If I don't get any answers I will let you know my self. Any heads up would be appreciated.
race car
Brickhole is offline   Reply With Quote
Old 02-25-2014, 02:11 PM   #2
daniel_f.
My Ride: 330iC
electrics are totally different!
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 02-25-2014, 03:46 PM   #3
Brickhole
My Ride: 325i
As in control unit and wire harness? Both I can swap. Or will swapping not work??
race car
Old 02-25-2014, 06:08 PM   #4
daniel_f.
My Ride: 330iC
Im not shure if swapping will be enough and to be honest i dont remember anyone else having it done. i guess you have to try it.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 02-25-2014, 08:25 PM   #5
Brickhole
My Ride: 325i
Exciting! Will take pics.
race car
Old 02-27-2014, 10:00 PM   #6
jdjg
My Ride: e39, m52tub30
manual transmision perhaps?
jdjg is offline   Reply With Quote
