Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 02-25-2014, 03:08 PM   #1
BMW325i freak
My Ride: 325i
Help please
I have a problem and hoping someone can help I have a bmw325i 1992 and it has run like a dream since I bought it seven months ago but this morning it started fine I drove to work without a problem but had to move it around an hour later and I now only turns over and won't start. I checked the fuel pump as no these can be a problem but it seems this isn't the problem as checked with circuit tester and there only seems to be power to one of the plugs. I have checked relay switch and this is fine so any ideas...?
BMW325i freak is offline   Reply With Quote
Old 02-25-2014, 03:12 PM   #2
bratliff
My Ride: 330i
Are you saying only one spark plug has power?
'02 330i
'97 318i
'95 325 Vert
'76 280z
bratliff is offline   Reply With Quote
Old 02-25-2014, 03:23 PM   #3
choxor
My Ride: JDM
Wong forum.
Old 02-25-2014, 06:15 PM   #4
BMW325i freak
My Ride: 325i
No sorry my car terminology is not good there are 2 ports on the fuel pump under rear seat 1 I presume is for gauge and other is for pump the plugs that attach to these only 1 seems to have power. The pump doesn't seem to be working but bought a replacement and that is the same so can't be the pump that's when I checked the power and found what may be a problem I then checked the fuses and these all seem fine.
