Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 02-27-2014, 07:44 PM   #1
Guest100615
Account closed per your request
conduits
I know that some pvc pipes and some wiring is not appropriate for using inside walls.
But what makes it unsuitable? I always thought that it was because the plastic covering the wiring was not fire proof. But what difference does it make if you are running it through wooden 2x4's ?
It is not like wood is fire proof.
Guest100615 is offline   Reply With Quote
Old 02-27-2014, 11:06 PM   #2
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
One reason: The wrong type of material releases toxic chemicals when burning
Another: The wire jacket isn't thick enough, grounded correctly or suitable for the environment
JonJon is offline   Reply With Quote
Old 02-27-2014, 11:20 PM   #3
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
Codes are your friends.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 02-28-2014, 09:27 PM   #4
ryanwhite74115
My Ride: 2013 Infiniti G37S
As an attorney I have to agree and disagree. Codes were designed to prevent morons from doing certain things. Problem with argument is sometimes morons write the code.
ryanwhite74115 is offline   Reply With Quote
Old 02-28-2014, 09:32 PM   #5
Guest100615
does it really matter if it gives off a gas when burning if you are going to run like heck when you see the fire........it's not like you are going to stick around.
correct me if i am wrong, but this is also why salt treated lumber / green wood is restricted to where it can be used ?
yes they are, but there are a lot of them.
Old 02-28-2014, 09:53 PM   #6
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Poisonous gases in your walls travels to different floors ahead of fire, especially if it gets into your ducts. People don't die from fires... Typically smoke is what kills you. Poisonous smoke is obviously worse than regular smoke.
The idea is to give the human the best odds to escape as possible
PT wood is chemicals too
Old 03-01-2014, 08:23 AM   #7
GlockMan
GlockMan's Avatar
Yea, it matters.
Consider an office building with plenum wiring. A fire starts 1000 feet away and the poisonous fumes are carried through the A/C system to an office that has no clue there is or was a fire.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 03-01-2014, 09:35 AM   #8
Guest100615
Yea, it matters.
That makes sense. I never thought about it that way.
Thanks.
