From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast
Old 03-01-2014, 07:35 AM   #1
beņat
Problem BMW 328i e46 not max rpm
hello. I have a problem with my 328i e46 race. lobque happens is that I canceled the abs and inatrumentos box and I left the ews and sensors with the engine control unit. what happens is that it goes up to 7000rpm horn in 4 runs to 5200. till then not turn off and restart the car bo horn that goes well 4 ya I put up no more 5200.must connect the unit to have abs infprmacion sw speed or to do something in the engine control unit. I've tried everything and I can not think nasa. thank you advanced.
beņat is offline   Reply With Quote
Old 03-01-2014, 09:29 AM   #2
Kayss
My Ride: Bmw 328i 1999
What?
Sent from my SGH-I337M using BimmerApp mobile app
Kayss is offline   Reply With Quote
Old 03-01-2014, 09:42 AM   #3
beņat
the car does not exceed 5200 rpm in 4 speed. idk if it's because when you remove the control abs brakes the ECU knows the engine speed at which the car is and short.or if the problem comes from something else. whether to override something in the engine control unit or so.
Old 03-01-2014, 09:42 AM   #4
beņat
Old 03-01-2014, 09:59 AM   #5
///Mpower3357
My Ride: 00' 323i
Question #1: are your dash lights on? Abs, dsc, pad wear, red brake light?
///Mpower3357 is offline   Reply With Quote
Old 03-01-2014, 10:02 AM   #6
beņat
I have not installed anything.
Old 03-01-2014, 11:04 AM   #7
beņat
I have just put the ecu and ews
Old 03-01-2014, 11:56 AM   #8
///Mpower3357
My Ride: 00' 323i
I give up, maybe talk to someone about ur issues in your native language. Your just not making any sense, unless someone else here can translate what your talking about.
Old 03-01-2014, 12:00 PM   #9
beņat
My native language si de spanish. I speak spanish and french. Someon understand spanish or french?
Old 03-01-2014, 12:01 PM   #10
///Mpower3357
My Ride: 00' 323i
I understand you have the ecu and ews installed. But other than that, what is your "race" car comprised of? No dash cluster to report what lights are on? If so are you reading rpms with an aftermarket tachometer? BMWs arent like hondas, you have to have everything from the ecu to the ignition correctly set up, otherwise the car wont run.
