E46 Xi Forum
Old 03-11-2014, 10:57 AM   #1
k3m0-330i-e90
My Ride: e90 335i,e46 M3
Send a message via AIM to k3m0-330i-e90
drive line issues
Hello. Have a question regarding driveline issues. My e46 is a 325xi and i bought it making banging nosies right away knew it was drive shaft center support bearing. So i replaced that and still having a issue. I belive that they drove on a shot bearing making the ujoints go bad. Now question is dose that sound right and is the drive shaft blannced like front with rear do i have to replace both or could i just do one?
Current 2008 335i e90- JB4 - Full Bolt on mods
2003 E46 m3 Vert
2000 328ci e46 - sold
2002 Taig / Red / / / M3 - SOLD
2000 328i e46 - sold
1993 325i e36 - sold
2006 330i e90 - sold
k3m0-330i-e90 is offline   Reply With Quote
Old 03-11-2014, 11:40 AM   #2
SamDoe1
My Ride: 4cyl of fury
Going to need more info than this. Where/when/how does the "banging" sound happen?
Old 03-12-2014, 06:55 PM   #3
k3m0-330i-e90
Well the banging sound was happening while the center bearing was shot like rubber was coming off. So guessing that the drive shaft was banging around it messed up the u joints. And once u pass 10-15 mph there's this vibration and when speeding up is bad but once off the gas it really vibrats badly. Making me thing the drive shaft lost alignment and the joints went bad.
2003 E46 m3 Vert
Old 03-13-2014, 12:34 PM   #4
Busy
Location: Guys, stop spraying your wheels black; it looks awful.
My Ride: 01 330xi
The vibration is likely the CSB either not being adjusted or seated right, OR the shaft wasn't reassembled perfectly after the bearing was slipped on. Ask the tech if he marked the shaft.
Busy is offline   Reply With Quote
Old 03-13-2014, 04:53 PM   #5
k3m0-330i-e90
shaft was marked and is dot on.. and bearing is put on good but is it possible for the u joints to go bad?
2003 E46 m3 Vert
Old 03-13-2014, 05:02 PM   #6
Busy
My Ride: 01 330xi
The shaft is balanced as one piece, and the machine-shops near me say they cannot be balanced aftermarket. Yes, we've seen e36 u-joints bind plenty, so I imagine it's only a matter of time untill we see the e46s do the same.
Old 03-13-2014, 05:06 PM   #7
k3m0-330i-e90
well because this is what was the problem... the owner before me was driving on a shot center drive shaft bearling like to the point where there was no rubber on the bearing and the drive shaft had a lot of play and im thinking that the ujoints got messed up because of it banging around on the bearing housing. understand..
2003 E46 m3 Vert
