E46 Xi Forum
Old 03-17-2014, 03:56 PM   #1
bubela
My Ride: 330tti/e46M3t
Front end chatter
I'm new to the 325xi front suspension here..
I'm getting a front chatter/clapping sound coming from the front end.
My thoughts were that the pads were lose and clapping. The higher the speed, the faster the "clap". As soon as I apply just a little bit of the brakes, the clap goes away.
Does this have to do with the brakes? I've also read that the front lower control arm busing may be a culprit. Is this so?
I have it up on the lift and the rubber LCA bushing is soft. It doesn't seem "bad" but definitely not as tight as a poly bushing would be. There is a slight shimmy at highway speeds as well.
Please forgive me if this is a common problem, but is there an obvious fix to this brake "clap"?
www.prussianmotors.com
95 PT6262 Forged 330ti 10.9@134@21psi
03 M3 MaxPSI on e85 11.48@128@19psi
bubela is offline   Reply With Quote
Old 03-17-2014, 05:07 PM   #2
SamDoe1
My Ride: 4cyl of fury
If you have it on the lift, go around and shake stuff because it sounds like something is loose.
shimmy and wandering feeling is probably either the ball joints or the FCABs. Again, go under there and shake stuff and see if anything moves around. If you have the wheel in the air, grab it at 12 and 6 and shake vertically, if it moves it's probably the ball joints. Grab at 9 and 3 and shake horizontally, if it moves it's probably the FCABs.
Old 03-17-2014, 05:54 PM   #3
bubela
That's the thing.. I don't have movement anywhere. All the bushings are tight under this shake test. I'm going to take the caliper/pads apart and see if anything is amiss.
Old 03-17-2014, 09:31 PM   #4
jmo69
My Ride: 03 325xi 98 328is
I had an issue with a brake that rattled and it was the anti-rattle clip had come off, the noise went away when the brakes were applied. It only seemed to make noise on bumps.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is online now   Reply With Quote
Old 03-17-2014, 10:32 PM   #5
Kubica
My Ride: 2003 325xi
Most likely brake backing plate or swaybar link.
Old 03-20-2014, 08:42 PM   #6
bubela
I took the calipers and pads off. Didn't notice anything abnormal. Just used a wire brush and cleaned up all the contact/sliding surfaces. Applied some anti-seize to said surfaces and re-assembled. Seems to have gone away. I'll let you know if it comes back.
Old 03-22-2014, 06:06 PM   #7
YaSureYouBetcha
My Ride: 2002 325xi
Sway bar end links...
You'll need to lift the front end to take the weight off. Grab them and shake, if there's any play whatsoever, that's your culprit.
YaSureYouBetcha is offline   Reply With Quote
Old 03-23-2014, 01:04 PM   #8
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
The slight "shake" you have at highway speed, does the steering wheel shake? Does it go away like the noise when the brakes are applied?
tomoyer is offline   Reply With Quote
Old 03-23-2014, 01:07 PM   #9
bubela
I feel the vibration in the steering wheel, but it does not move the wheel left/right. Pretty sure it does not go away when the brakes are applied.
