Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 03-17-2014, 07:22 PM   #1
joeski3d
My Ride: 2000 323i
Gutter Replacement
This winter's snowfall put an end to the gutters on the back of my house. Fortunately it's not long or complex. I have one 90 degree angle and two downspouts.
Anyway, this will be my 1st gutter install. Are there any notes that anyone has learned that would be of use to a novice?
Ballbusters Inc.
DISCLAIMER: No balls were physically hurt during the reading of this post. Should redness and/or swelling occur consult your gynecologist immediately.
joeski3d is offline   Reply With Quote
Old 03-18-2014, 07:59 PM   #2
Guest100615
Account closed per your request
I have never had to replace any gutters, I just climb up top once a year and hammer in the nails that have come loose.
One thing I have considered is (If I ever have to replace them.) using some decorative downspouts or straps. There are some really nice ones available and I think they could add a bit of personality to the home. Inexpensive as well........
https://images.search.yahoo.com/sear...orative+gutter
http://www.rutlandguttersupply.com/hangers/Hangers.asp
http://www.guttersupply.com/p-Orname...Brackets.gstml
http://www.guttersupply.com/p-products-ornamental.gstml
Guest100615 is offline   Reply With Quote
Old 03-18-2014, 08:27 PM   #3
joeski3d
My Ride: 2000 323i
Thanks Raymond. I may just have to do as you suggest. I'll have to check the board that the gutters are nailed to but I just assumed it was going to need replacement. I do want to get a good leaf blocking system on the back gutters though. There are a great number of trees that use my drainage system as a trashcan. Any suggestions there? I've tried some wire mesh stuff but the foliage just laughs at that stuff.
Ballbusters Inc.
Old 03-18-2014, 09:23 PM   #4
Guest100615
I have trees at the end of my yard , but not around the house.
I don't have a real need for the leaf guards.
I have read that the leaf guards 'collect' leaves and that water flows over the leaves and not into the gutters. That may not apply to all of them but I am sure it is relevant to a few.
What you may want to consider is a screen that you put in the top of the downspout to keep leaves from clogging up the downspout. I have never used it, but it's an idea.
something like this.........
http://www.homedepot.com/p/Unbranded...6?N=5yc1vZar5e
Old 03-22-2014, 10:55 PM   #5
5ynd1cat3
My Ride: pisses off liberals
Joe you need to get that cool robotic gutter cleaner like Phil in Modern Family. Then you could just sit in a lawn chair sipping iced tea like a bauss while simultaneously cleaning your gutters!
5ynd1cat3 is offline   Reply With Quote
