Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 03-31-2014, 12:05 AM   #21
ReeceEngM54
My Ride: E46 330ci
What grinding tool were you using to port match?
ReeceEngM54 is offline   Reply With Quote
Old 03-31-2014, 06:00 AM   #22
SoloII///M
My Ride: Many
Pneumatic die grinder with various fluted burs to cut and cartridge rolls to finish.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 03-31-2014, 09:07 AM   #23
SoloII///M
My Ride: Many
Major advantage to this manifold that I hadn't really considered before - it is amazingly quick to install and remove. I've had the thing on and off the car probably 50 times fabricating brackets, running wires and hoses, etc and even with everything fully assembled I can have the manifold out and on the ground in no more than two or three minutes. Try that with an M54!
John V
Old 03-31-2014, 09:48 AM   #24
sm240
My Ride: 95 240sx
Subbd
sm240 is offline   Reply With Quote
Old 04-03-2014, 07:29 PM   #25
SoloII///M
My Ride: Many
Well, it runs! Fired it up with no issue and loaded a new temporary map into the VE table in the MS3. Hoping to get down to Virginia Beach for a new tune next week or maybe the week after
John V
Old 04-03-2014, 11:36 PM   #26
sm240
My Ride: 95 240sx
That's great. Do you have any idea where the injectors max out?
Old 04-04-2014, 04:46 AM   #27
SoloII///M
My Ride: Many
Somewhere well north of my power level. They're 42lb/hr.
John V
Old 04-04-2014, 09:38 AM   #28
sm240
My Ride: 95 240sx
Yeah that's good for at least 350hp. Great job man, looking forward to seeng the numbers
Old 04-04-2014, 11:28 AM   #29
SoloII///M
My Ride: Many
Well, I sized them to have headroom when I was running E85 which requires like 30% more fuel for the same power level as straight gas. thanks, I'm looking forward to hitting the dyno as well.
John V
Old 04-04-2014, 03:41 PM   #30
hoveringuy
My Ride: e30
Pics? How did you plumb the ICV and CCV?
hoveringuy is offline   Reply With Quote
Old 04-04-2014, 05:51 PM   #31
Iceman00
Banned User
My Ride: E90 6MT
Oh yeah?!
Old 04-04-2014, 09:39 PM   #32
SoloII///M
My Ride: Many
Pics of what?
I used E36 ICV hoses and junctions and bolted the E46 ICV bracket to the underside of the manifold. It all lined up pretty well and ends up plumbed exactly as an OBD-1 E36 325i/is would have it.
For now, I ran the CCV as follows. I cut off the plastic crankcase line about 6" down from where it leaves the VANOS unit, where it passes under the plenum. I then used sections of rubber hose and hose barb reducers until it was small enough to connect to a 3/8" hose barb tee. I teed it into the intake boot at the same place where the F-connector is on the stock E46 intake tube, so the fuel pressure regulator and the sucking jet pump are connected as stock. I capped off the dipstick tube where the CCV previously connected to it. My MAP connection is at the back vacuum port underneath the manifold, near the back of the plenum. And I deleted the purge valve and the charcoal canister. We never were controlling it with the MS. The brake booster line is cut short after the sucking jet pump and connected to the back of the plenum, topside, just like an E36.
Eventually I'll probably make up some sort of air/oil separator, but for now this will give enough crankcase vacuum to not hurt performance.
John V
Old 04-04-2014, 09:39 PM   #33
SoloII///M
My Ride: Many
Originally Posted by Iceman00 View Post
Oh yeah?!
Uh... okay?
John V
Old 04-05-2014, 07:48 PM   #34
Iceman00
Banned User
My Ride: E90 6MT
Originally Posted by SoloII///M View Post
Uh... okay?
I thought we were having a dyno showdown.
Old 04-06-2014, 02:04 PM   #35
ReeceEngM54
My Ride: E46 330ci
You should just install a vacuum pump for the CCV and add a catch can before it gets to the pump. It seems to me feeding spent exhaust gasses back into the intake is going to hurt performance more that spending a few ponies to run an additional pump.
Old 04-07-2014, 05:04 AM   #36
SoloII///M
My Ride: Many
It's definitely drawing too much vapor back into the intake with how I set it up. I'm going to go the catch can route to alleviate that. The engine is a good enough vacuum pump so I'll use that
John V
Old 04-07-2014, 01:19 PM   #37
ReeceEngM54
My Ride: E46 330ci
But then you aren't getting as much fresh air with oxygen as you could, and its not going to pull as much of a vacuum.
Old 04-07-2014, 01:31 PM   #38
SoloII///M
My Ride: Many
Okay.
John V
Old 04-08-2014, 02:00 PM   #39
SoloII///M
My Ride: Many
I didn't think we were. But if we were... wouldn't you want to post a strong dyno?
OOH BURN!
Just kidding.
John V
Old 04-08-2014, 02:35 PM   #40
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
osnap!
OOH BURN!
Just kidding.
