Old 03-27-2014, 08:52 AM   #1
Leooo
My Ride: 330ci
Clutch overheating
Hi Guys,
last weekend I tracked my almost stock 330ci.
The car held up phenomenally, I really love the new HSD coilovers. However, after about 20 minutes of hard downshifting in to second gear, the clutch was overheated.
At least I think it overheated because of the beating it took. The clutch held until 3000 rpm but after that it disengaged and the rev indicator took off. I was able to drive back to the pits. When I let it cool down for 30 minutes, it was working fine again. I took fewer corners in second gear and the clutch kept on doing its job for the remaining four 20 min heats.
The clutch is in the car since it left the factory and it has done 278k KM (173k miles)
I would like to replace the clutch but I've no clue on what brand to take.
It's a project car and is for track use only, so a 6 puck clutch is no problem.
Could you guys help out with the experiences you have had?
Thanks in advance!
Leooo is offline   Reply With Quote
Old 03-29-2014, 11:27 PM   #2
Minnoe07
My Ride: 2004 BMW 330Ci
I have a clutch masters fx250 and like it a lot. Slightly firmer clutch pedal. Clutch masters has a great line from street friendly to hardcore track.
With that mileage, you are also due for a new flywheel. Up to you, but I went with an OEM dual mass instead of a lightweight cause I don't want my car to sound ghetto with transmission rattle.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 05-21-2014, 12:45 PM   #3
wallofgrath
My Ride: 2001 330Ci
Sounds like you need a new clutch. I recommend Exedy OE replacement paired with stock dual mass flywheel or the heaviest aftermarket steel flywheel you can find.
I'm new to the BMW world but I've been through a number of clutches on other cars... ACT & ClutchMasters both burned out early. Maybe it was me/my car, but they cost twice as much as OE replacement clutches and offered me no extra benefits. I've run Exedy OE replacement clutches on my past WRX (350+ hp) and G35 and it felt great on both (a little stiffer than stock) and only cost $250 (looks like they are $430 for BMW). Big name company and quality part. Also I installed a lightweight steel flywheel (not super lightweight aluminum) on my past WRX and it was noisy. So I installed a OE replacement dual mass flywheel on my G35 - no noise but expensive as hell.
wallofgrath is offline   Reply With Quote
Old 05-21-2014, 06:12 PM   #4
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
OP,
First read this, then ask questions.
http://forum.e46fanatics.com/showthread.php?t=1017883
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 05-21-2014, 06:20 PM   #5
Rob43
Rob43's Avatar
Double Post.
Old 05-21-2014, 09:49 PM   #6
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I ran the OEM clutch at the track...never had a problem.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
