Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 1.00 average. Display Modes
Old 04-01-2014, 10:13 PM   #1
ewdavis3
Shaking steering wheel
I just changed the control arms & bushings on my e46 325i. next will be tie rods... hope this fixes my annoying shaking steering wheel.
ewdavis3 is offline   Reply With Quote
Old 04-01-2014, 10:14 PM   #2
JapanRot325ci
My Ride: 04 E46
good luck! update us after changing them.
JapanRot325ci is offline   Reply With Quote
Old 04-02-2014, 12:15 AM   #3
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Since you just did your control arms and bushings, the only things that could cause shaking are 1.) tire balance or 2.) alignment.
hi its me alec is offline   Reply With Quote
Old 04-02-2014, 05:00 AM   #4
NumbaOneNewb
My Ride: 2003 330CI Silver
Agreed
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-02-2014, 06:07 AM   #5
paraklas
My Ride: ESS TS2 320ci
and wheel bearings, worn strut mounts, bent alloys
Old 04-02-2014, 10:47 PM   #6
ewdavis3
Tires are balanced... not sure on alignment
Old 04-02-2014, 10:49 PM   #7
ewdavis3
I do need to check strut mounts and wheel bearings!
Old 04-02-2014, 11:08 PM   #8
racin366
My Ride: 04 325ci
Do a careful VI on the tires, could be a small blister or the like, you'd be surprised how much shaking a minor looking tire issue can cause, Beyond that I'd check all the bushings, ball joints, and dampers. Can you give some more info about the shake, like is always there when moving, only when turning, certain speed range, etc?
racin366 is offline   Reply With Quote
Old 04-03-2014, 12:24 AM   #9
Jools
My Ride: 2005 330Ci
Don't forget the really obvious ones too: tire pressure, brake rotors, seized caliper. Doing my brakes solved literally all of my vibration issues.
Also, suspension issues like FCABs, etc. can be pretty reliably checked. There's no need to go replacing parts blindly.
Jools is offline   Reply With Quote
Old 04-03-2014, 12:30 AM   #10
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
Why would you think any of this could cause a wheel shake?
Cavi Mike is offline   Reply With Quote
Old 04-03-2014, 12:47 AM   #11
ewdavis3
Car has brand new tires, brakes & rotors
Old 04-03-2014, 12:48 AM   #12
ewdavis3
Going to check my tie rods & strut mounts tomorrow!
Old 04-03-2014, 12:54 AM   #13
ewdavis3
At low speeds the steering wheel doesnt shimmer that bad but the faster I go the worse it gets.... really takes away from the driving experience.
Old 04-03-2014, 12:59 AM   #14
ewdavis3
Just had new brakes and rotors installed... still shakes
Old 04-03-2014, 01:00 AM   #15
ewdavis3
The new control arms and bushings helped some
Old 04-03-2014, 01:11 AM   #16
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
What is your wheel tire setup? Could be one of the wheels is slightly off balance but you said they were balanced. From the symptoms you provided, my guess would be tires or the struts are worn.
HacksawMark is offline   Reply With Quote
Old 04-03-2014, 01:15 AM   #17
Jools
My Ride: 2005 330Ci
Any signs of uneven or unusual tire wear?
Old 04-03-2014, 10:00 AM   #18
racin366
My Ride: 04 325ci
That sounds like a tire problem, just because they are new doesn't mean they don't have a problem.
Old 04-03-2014, 10:06 AM   #19
ewdavis3
Have not changed the tie rods yet, going to have my mechanic check them out today!
Old 04-03-2014, 11:31 AM   #20
Benny Minn
My Ride: 2004 325xiT 5-speed
With many BMWs the FCAs and FCABs are the most common culprit for a shimmy in the steering wheel. It seems natural to consider those for the E46 as well.
Benny Minn is offline   Reply With Quote
