Sponsored by BimmerWorld
Old 04-04-2014, 08:20 PM   #1
CoryAshton
My Ride: 2003 325i turbo
Rear end noise
I recently started to hear a noise coming from around my back right tire. The noise speeds up with the speed of my car, but if I accelerate it goes away. I've spent all week trying to figure out what it is but just cant. It's a loud squeak/ knock and only does it when I'm rolling. I've taken the tire off and spun the rotor to see if I can hear it but I can't. Any input?
CoryAshton is offline   Reply With Quote
Old 04-04-2014, 08:46 PM   #2
swaggerwagon
My Ride: 2005 330i
put the back end on jack stands and turn off the DSC run the car and get it to about 60 and pop it in neutral listen for a noise as would indicate a wheel bearing. does it happen over bumps more or rolling on smooth flat
330i ZHP
3 Pedals FTW
BMW level 2 Tech
Ebay headers | Long tube CAI | modbargains ///M pedal covers | SS clutch line | CDV removed | Turner camber arms | Meyle HD FCABs | uuc poly motor/trans mounts | Eurospec Muffler | Clutch masters Stage 2 with aluminum flywheel | Coilover kit | CSL front bumper | Z4m shift lever | VISracing CF hood | Depo HID w/CCFL halo rings
swaggerwagon is offline   Reply With Quote
Old 04-04-2014, 09:05 PM   #3
CoryAshton
Just replaced both wheel bearings, it does it all the time unless accelerating. Bumps don't effect it.
Old 07-26-2014, 12:17 PM   #4
CoryAshton
Anybody else experiencing the same problem? The noise tends to lighten up whenever the clutch is in or in neutral. When coming to a stop it becomes a longer squeak. It has to be something rotation because as I'm coming to a stop it goes in and out and you can hear it squeaking at a certain point.. It's getting very frustrating.
