Old 04-04-2014, 09:34 PM   #1
bluba
My Ride: 2002 m3 HPF stage 2
Tire set up for rear on stage 2/pro efi
Ok what size rear tire can I use on stock suspension and 19" m6 time attack replicas? I like the r888 but don't think 295s will work. I have TR1 toyo on now. Rear tires are shot. Btw no fender roll either done. Thx
HPF stage 2 turbo with pro efi e85
dinan 3;91 gear
bluba is offline   Reply With Quote
Old 04-04-2014, 09:54 PM   #2
Commanderwiggin
My Ride: 900rwhp Turbo M3
295 R888's are going to be your best bet...ROLL THE FENDERS! Find someone good to give you the space.
Second bet that won't require a roll...275/30/19 NT05's guaranteed to fit...but the 275/35/19's get more traction but likely need some roll...and the R888's well...traction is a guarantee with those.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 04-04-2014, 10:02 PM   #3
bluba
Thanks, is the rim width ok with the rims I have when using r888?
dinan 3;91 gear
Old 04-04-2014, 10:08 PM   #4
Commanderwiggin
My buddy Dallas runs those tires on a Cor 19x10.5 or 19x11 with aggressive offset...you will fit with a proper fender roll...find a good place to do it that pulls the gunk out before rolling.
Old 04-05-2014, 12:23 AM   #5
imapimp
My Ride: 2002.5 AV6 6MT 04M3
I'm running the nt05's 275/35/19 and they rub slightly. Was told need to raise the rear 1/4 inch so i decided to go get the fenders rolled instead. Going Mon morning and i'll report back with how much it helps and before/after pics.
imapimp is offline   Reply With Quote
Old 04-05-2014, 04:55 AM   #6
bluba
thx
dinan 3;91 gear
Old 04-05-2014, 09:22 AM   #7
dallasberry
My Ride: ///M3
Here's how my 295's fit on a 19x10.5 rolled fenders running -2.0 degrees Camber.
Here you can see they tuck nicely under load (Watch in full screen)
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline   Reply With Quote
Old 04-06-2014, 10:25 AM   #8
bluba
Real nice
dinan 3;91 gear
Old 04-06-2014, 05:52 PM   #9
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Your camera did most the tucking. Lol!
Old 04-06-2014, 06:05 PM   #10
JohnBlaze
My Ride: Black Sunshine
sick, sounds really clean
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 04-06-2014, 07:22 PM   #11
bluba
Ok found a local guy to roll the fenders so going with R888... Should I get this from lab 22 or recommendations???
dinan 3;91 gear
Old 04-06-2014, 07:52 PM   #12
Commanderwiggin
Whoever sells the tires get em
Old 04-07-2014, 09:15 AM   #13
dallasberry
My Ride: ///M3
What he said! I just shopped around online for the best price.
Old 04-08-2014, 12:33 AM   #14
imapimp
When you guys go you fenders rolled was it jus the metal that slanted upwards or did you do the bottom part too? Hopefully, I'm wording this correctly as mine we were only able to do the slant and the guy that does the rolling said in order to do the bottom part there may paint damage.
Old 04-08-2014, 09:48 AM   #15
nek0
My Ride: e85 turbo m3
this is 275/35/19 rear tires is et20 10 inch wide... my fenders are not rolled although they are cut and sealed for maximum clearance
I also have a pair of 18 apex arc-8 the rear is 285/35/18 10 inch wide offset is et25
both of them hook very nicely and both of them have the same tires on them nitto Nt05
to my understand toyo R888 are the best tire for some grip but have a life spand of 3000 miles depending how you drive them and we all know your not gonna be babying the car around... also if you ever get caught in a rain storm they are scary to drive in the rain
nek0 is offline   Reply With Quote
Old 04-08-2014, 10:33 AM   #16
bluba
Only 3000 miles on r888?? Well maybe I will rethink the NO5 cause I can let the pro efi traction control do it's job. Thank
dinan 3;91 gear
Old 04-08-2014, 04:49 PM   #17
Commanderwiggin
Traction > Traction Control...faster as well. You drive a 600+hp car who the fvck cares about tire mileage.
Also the NT05's are great in the rain...R888's also work very well in the rain...I have driven them through a torrential downpour several times.
