Old 04-05-2014, 06:32 PM   #1
Bimme323
My Ride: Bmw e46
BMW 323i nitrous FINALLY!!!
After a month, finally got to finish my nitrous project.
It goes to all of you who talked bs on my last nitrous post.
Here is the parts list:
-Zex wet kit 55 to 75 shot
-AEM fuel pressure regulator
-MSD rpm switch.
-MSD adjustable rpm module (3000 to 5800 rpm)
-MSD rpm module 5600 rpm
-zex spark plugs
-zex purge kit
-AEM wideband failsafe (not installed yet)
As of now im running a 30 shot. Using a .027 nitrous .015 on fuel. Its a noticeable +30hp.
Will get back to you when i take it to the dyno with the afr gauge installed and a progressive controller.
Here are some pics
ID:	552811Click image for larger version
ID:	552812Click image for larger version
ID:	552813Click image for larger version
ID:	552814Click image for larger version
Bimme323 is offline   Reply With Quote
Old 04-05-2014, 06:41 PM   #2
JasonLI25t
My Ride: 2000 323ci
the fact that you installed it does not make any of us wrong. good luck with your kit. please post when you are engine shopping. i like how the wideband isn't even installed yet. nice.
JasonLI25t is offline   Reply With Quote
Old 04-05-2014, 06:51 PM   #3
Bimme323
My Ride: Bmw e46
Thats what i meant about bs. Most of us come here for help and most of the time we end up finding smart*** like you.
Old 04-05-2014, 06:52 PM   #4
Bimme323
My Ride: Bmw e46
Wideband will be installed at tyme of dyno for 50 shot!!!
Old 04-05-2014, 06:58 PM   #5
JasonLI25t
My Ride: 2000 323ci
agreed, i am smart.
you're doing it wrong. the wideband is your lifeline to know what's going on in there. tuning 101. start a little rich and lean it out. you slapped this kit on and tested it out essentially blind. way to go. you're lucky it didn't pop already. we all know you can make copious, easy horsepower with nitrous. if there was no downside risk, it would be incredibly common.
Old 04-05-2014, 07:00 PM   #6
JasonLI25t
My Ride: 2000 323ci
good tymes, good tymes.
Old 04-05-2014, 07:06 PM   #7
e46alfonso
My Ride: 330xi MT, mustang gt
you are lucky that 50 shot didn't blow the welds on the intake.
Old 04-05-2014, 07:20 PM   #8
Bimme323
My Ride: Bmw e46
Im not running 50 shot. Is only 30 shot for now
Old 04-05-2014, 07:25 PM   #9
Yassrab
My Ride: 2004 BMW 325xi
Nitrous always use to be my first mod in Need for Speed , GG
"If one day the speed kills me, do not cry because I was smiling" - Paul Walker #RIP
Yassrab is offline   Reply With Quote
Old 04-05-2014, 07:28 PM   #10
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
OP, congrats on what you've accomplished so far.
You should ask the Mods to move this thread to the F/I forum, you'll get little to no BS in the appropriate sub forum.
PM on the way.
SUMMIT POINT WV 1:24:229 SCCA
Old 04-05-2014, 07:46 PM   #11
Bimme323
My Ride: Bmw e46
How you do that?
Old 04-05-2014, 07:51 PM   #12
Rob43
Rob43's Avatar
How you do that?
Click on the little red & white triangle located in the bottom left corner, then follow directions.
Old 04-05-2014, 07:56 PM   #13
phoopsta
My Ride: 02 330xi 3-pedal
i like
______________________________________________
phoopsta is offline   Reply With Quote
Old 04-05-2014, 08:40 PM   #14
Bimme323
My Ride: Bmw e46
Is that using the app or on the webpage
Old 04-05-2014, 08:47 PM   #15
BeMyWhip
My Ride: 01 BMW 330ci
Man. Awesome job. I was looking to add a 50 shot myself.
Did you do it yourself, or did you have it installed?
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 04-05-2014, 08:54 PM   #16
Bimme323
My Ride: Bmw e46
Thanks. I did it my self.
Old 04-06-2014, 11:52 AM   #17
autoAER
My Ride: 2005 325i 5MT
Is that a stock m52?
Also, why is there a black fire extinguisher behind your seat?
Past: 2006 330i, 2006 325i 6MT, 2003 325xi
Current: 2008 335i E90 N54, 2005 325i 5MT
autoAER is offline   Reply With Quote
Old 04-06-2014, 12:25 PM   #18
BimmerTech84
My Ride: 05 ZHP, 98 Jeep 5.9
Poor car. I would sell the BMW and buy a Camaro or Mustang if this is how you mod your cars. Forcing a poor 323 to literally kill itself (wait and see, I will be right) just so you can pull on a couple 330i's or a few bone stock mustangs with bad drivers is asinine. You do know your intake is made of plastic and will explode extremely easily, right? If you like learning hard lessons from first hand experience, party on bro! I give you no more than 15-20 pulls with a 50 shot before you start seeing problems with your engine. This thread makes me laugh and cry at the same time.
Evan
H&R race, Hamman PG2 18x8 square setup, 225/40/18 Conti DWS Extreme Contact, Dinan Airbox, Dinan Muffler w/ resonator delete, Dinan Stage 2 software, Black Cube trim, BMW Performance weighted shift knob, All Maintenance up to date, Hardwired V1, BMW OEM LED interior lighting, Depo Clear lenses with OEM sidemarkers
BimmerTech84 is offline   Reply With Quote
Old 04-06-2014, 12:37 PM   #19
JasonLI25t
My Ride: 2000 323ci
this. and he thinks we are just being jerks. nitrous has its place and it is not on a bone stock M52tu.
the fact that he did a few pulls without the wideband even installed tells me he isn't going about this the right way. If you have any chance of keeping the engine from grenading on you, you need to keep track of the AFR constantly. If i were you, i would not have done any pulls that triggered the nitrous until i was actually ON the dyno with both the wideband installed AND the tailpipe sniffer of the dyno setup so you can accurately and safely hone in your wet nitrous shot. given the difficulty in "tuning" these engines as far as timing and trims are concerned, i am not sure you will ever have a truly clean or safe setup. this looks a bit hacked together. i also don't like the nitrous bottle on the floor of the rear seat.
personally, i would have used this time and money towards a true FI system like a supercharger, which will make more power throughout the rev range and provide more reliability. it is worth the extra cost if you want real power in these cars, and i can't see that your wet Zex setup is that cheap either.
Old 04-06-2014, 01:17 PM   #20
Bimme323
My Ride: Bmw e46
I understand guys. I did two pulls using a .017 for nitrous and .012 on fuel. This was just to test the kit. I now it was crazy to run it without the afr gauge.
Im waiting for my tuner to call me to get the kit set up right. By the way my goal is only a 30 shot. Im not a street racers is just something to have and go to the track a couple of times in the summer.
